Shaft Alignment and Cutlass Bearing |
1989SN2001
Senior Member Joined: October-01-2010 Location: Canton, GA Status: Offline Points: 122 |
Posted: June-10-2011 at 12:40am |
Hi everybody!
I recently performed an alignment on my boat, it was pretty far out. I called the PO and he hadn't checked it in several years of ownership, so I don't know how long its been out of alignment. When I bought it, the prop would turn fairly easy by hand, I could even grasp the shaft and turn it with one hand, so I didn't think much of it. After performing the alignment, I can spin the prop with one finger, and it will continue rotating for about a full revolution after I let go. Much better. However, I went to install my new acme 470 today, as per Pete's "proper prop installation" thread (thanks, Pete!), and after completing it, I noticed some play in my cutlass bearing. I haven't put a dial indicator on it, but I'd guess its in the neighborhood of .01-.02 of total play. Now, I know the rule of thumb is if you can feel any play, replace the bearing. However, I'd really like to go boating this weekend, and parts from skidim won't be here for a couple days. Is this something I need to replace ASAP? What kind of damage can be caused from running a few hours with a worn out cutlass bearing? For what its worth, there was no noticeable play before I fixed the alignment, I guess the shaft was pulled tight in the cutlass by the trans coupling being out of place. Now that its aligned, the play is noticeable. Thanks again, TJ |
BuffaloBFN
I think you'll have your answer right after it's warmed up. I'd say use it if the vibration is minimal. I'd also ask Eric what to watch for in your situation.
