gauges swap? problems? |
91SN
Newbie Joined: August-24-2008 Location: United Kingdom Status: Offline Points: 38 |
Posted: October-18-2008 at 9:17pm |
will off the shelf 'Faria Euro White Style' gauges fit my 91 Ski Nautique?
my standard gauges look a bit tired! is it just a case of removing the old dials and popping in the new ones, or is there anything clever to do with the connections etc? can the speedos be swapped or will this lead to problems? any advise welcomed! |
They can all be swapped pretty easily. Gauge size (cutout) for the VDO's is 2-1/16", so double check the dimensions on the Farias. The gauges are very easy to remove- take your dashpod off and take a look. There is a C-bracket that holds them in- once that (and the wiring) is removed, they slide right out the front. I believe you could do the speedos just as easily.
