  New Posts New Posts RSS Feed - Fuel Injection Troubles
1998Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1998Nautique Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Injection Troubles
    Posted: October-25-2007 at 1:37am
Is there anything I can check on my fuel injection system, that would cause the hesitation. Or cutting out for 1.2 a second. I have changed pumps and filters and everything else.
87BFN owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2007 at 1:44am
Did you check the injectors themselves for pulse?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1998Nautique Quote  Post ReplyReply Direct Link To This Post Posted: October-28-2007 at 2:31pm
How can I do that? I can do you basic mechanic work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2007 at 6:07pm
You should be able to goto the local auto parts store and barrow or rent the kit. It's just a plug with an LED on it. It flashed everytime the injector activates. If it does not flash the injector is not working. I will try to find the proper name for it.
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2007 at 6:55pm
NOID
