Whats Missing? |
Post Reply | Page 12> |
Jtonor1
Groupie Joined: December-01-2006 Location: New Orleans, LA Status: Offline Points: 65 |
Posted: January-15-2007 at 2:43pm |
When inspecting the hull of my 89 nautique I noticed something that did not look right where the prop shaft goes through the hull. I don't think it is anything major but something is missing and I need someone to tell me what I need so I can replace it.
SkiBum
That's the way the bottom of my 87 SN looks. Seems like maybe there should be a fitting, seal, or soemthing but I dont know?
PLBC
Gold Member Joined: January-25-2006 Location: United States Status: Offline Points: 568 |
Nothing is missing
huey
Newbie Joined: August-20-2006 Location: United States Status: Offline Points: 20 |
That's how the bottom of my '91 looks.
quinner
Perhaps some sort of rubber as protection whenever the shaft enters the hole?
Mark Mel
Gold Member Joined: September-16-2005 Location: United States Status: Offline Points: 583 |
You should always use some sort of rubber protection when your shaft enters the hole.
Hollywood
Ok so if it's not some type of rubber protectant, I will guess a lubricant. The shaft/hole interface looks quite dry.
quinner
Hollywood, it sounds like you may be confused about which hole the shaft should be in, normally the correct hole is self lubricating.
SeattleFordFan
Senior Member Joined: April-18-2005 Location: United States Status: Offline Points: 190 |
Some holes have carpet around them, but arent usually that loose on the shaft, check for reproduction status, and perhaps aftermarket shaft enhancer?
Travs
Where there is a will, there is a way, and where there is a way, it usually costs more money. 1980 Ski Nautique |
Hollywood
Check with the previous owner to find out how many times the shaft has been removed and then put back in. An abused hole will get stretched out over time.
Jtonor1
Thanks everyone your your feedback; however, I think the later post will prove to be the most usefull. With topics like this it is always good the get the the right advice so that you can get the optimal pleasure out of your pleasure craft.
MaddMarxx
Putting your shaft in a dry hole is not good!!
SeattleFordFan
Always make sure your parts are clean before inserting your shaft into the hole, otherwise there could be some contamination, and with clean parts it is easier to find the source.
Travs
eric lavine
Hollywood, it turns into what's called a mudbucket and you dont have to be a sharpshooter
nates78ski
Platinum Member Joined: January-24-2005 Location: United States Status: Offline Points: 1041 |
If the hole's too dry... just spit on it.... works for me!!!!
Nate |
jbear
Wow...it must be gettin' to be a long winter for some of you guys.
john |
"Loud pipes save lives"
MaddMarxx
You must always make sure the hole is clean before you insert the shaft, the best way to do this is stick your nose in it and take a big whiff...and hope it dont smell fishy!!
huey
It's a good thing we're talking about a model year '89 here, or we'd all be going to jail.
boat dr
Boat Doctor here,
As best i can tell from the above posts,we are surrounded with some very sharp mechanical minds.But the winter nites are starting to affect the way the brain behaves. A little more sunlight is known to help with this illness."Lakabotime",is a progressive and potent life threatening malady. As of now there is no cure,some on this thread seem to have some of the cla$$is side affects,but Hrydrotherapy ,seems to help. jbear and i live far enough South that we can get our required dosage,for those further north come play with us......... |
eric lavine
If it smells like fish its a dish, if smells like cologne leave it alone
nates78ski
Smells like fish's a dish? aww god no!! haha the hole should be scentless.... Nate |
Hollywood
There seems to be some confusion on the matter. When it comes to the hole, maybe we should ask our resident expert, AbunDiga. You out there???
eric lavine
cologne is a covering agent
todicus
Senior Member Joined: July-10-2006 Location: Napa, Ca Status: Offline Points: 493 |
There is a store in San Fransisco called "Sucker's Liquor's"........ the sign on the window says "Liquor in the front, Poker in the rear"........
Just thought I'd share |
reidp
I'm not sure now if I'm ever gonna post another legitimate request for help after this thread, however I did have to share it with all the guys in the office. But I'm headed out now for dinner at a bar/restaurant called UNCLE MILF'S LAKE NORMAN TAVERN. I swear to God I am. (Yes, I listen to Bob and Tom on the radio, now and then, and Donnie Baker kills me). I'll post picts of it. If we have a Mid-Atlantic reunion we'll hang there.
boat dr
reidp, there are some sick puppy's that lurk around this site just waiting..........
Fins to the left Fins to the right Looks like a feeding frenzy |
nates78ski
It's been too long of a winter already... and my boat's only been in storage for 3 months, oh god i need warm weather!!!
Nate |
eric lavine
Reid , your near Statesville?
eric |
jbear
Nate: The boat dr and I got sunshine to spare down south here. The door is always open and the '80 is ready to get wet. C'mon down.
dr: you should try a trip down this way yourself. john |
MaddMarxx
Yeah boat dr...come on down.. Im always up for a good race...oh yeah.. and bring us some of that (shine)
