  New Posts New Posts RSS Feed - Checking timing
Checking timing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Topic: Checking timing
    Posted: December-04-2006 at 11:20am
Do any of you check your timing ever? I've always tuned my boats, but as I don't have a timing light, I've never checked the timing. They always run good after a new cap, rotor, points and condenser. If the timing is set right, does it get out of whack?
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: December-04-2006 at 11:57am
Yeh, the timing can change a little over time.... no pun intended. I think it is from timing chain strech and wear. (How do you spell strech?)
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: December-04-2006 at 2:27pm
add a T jim, stretch
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: December-04-2006 at 2:47pm
When you change the points and condenser,you change the timing. Even if the new parts are put back prefect,the old parts are worn. Set the dwell first then the timing. You need a tach-dwell meter and a timing light. Go electronic & all you need is a timing light.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: December-04-2006 at 3:08pm
The tack and dwell will tell me how good I got it with the feeler guage? It's a PCM 240 with a presolite distributor. There's not a spot to put that GM tool in to adjust while the engine's running like on the old GM engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: December-04-2006 at 5:45pm
Riley
     Dwell = degrees ( of a circle ) that the points are closed. Use the feeler gauge to set the points in the "ball park".Not sure but it it looks like it should be 24*-30* degrees "ish" depending on the year. The tach - dwell meter I have is an old craftsman I bought at a yard sale for $10 - 30 years ago - it still does the job! As the points wear, that changes. Change the parts ,start the engine & check the dwell - shut the engine off - use the feeler gauge with a "tight" or "loose" drag on the feeler gauge to tune the dwell. Get the dwell tweeked ,it should only the a couple of ajustments ,then set the timing. Dwell has a direct affect on timimg ,but; timing has no affect on dwell. If you can change the tune-up parts YOU CAN do it !
