Everything good? |
Author | |||
Tomrupp
Groupie Joined: October-14-2021 Location: MI Status: Offline Points: 73 |
Posted: October-27-2023 at 7:25am |
It’s so quiet here. I’m assuming that everyone is properly winterized and stored. Fresh oil, properly adjusted timing, etc… Maybe everyone is in a wet sanding and buffing to get the perfect shine for spring. I’m blaming the Grand Poobah’s for answering all of the questions and having all Correct Crafts running perfectly. Everything is good for me. Garage stored with a red oil filter to match valve covers. Can’twait for spring or at least another post here….
Tom
94 Ski Nautique Open Bow 351 with Carb 95 Double Decker Aqua Patio with 50hp Honda (3 carbs). |
rebel skier
Gold Member Joined: October-17-2014 Location: Middle Tenn Status: Offline Points: 772 |
Not here -- still waiting for my custom new axle from Indiana so I can run the boat a few more times. Boat is laid up at a trailer shop. I have drained all the water from it though. It's ready for the first freeze.
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1731 |
Two of three winterized. Other is in heated garage just in case!
pjsmoreno
Senior Member Joined: April-25-2016 Location: Liberty, Mo Status: Offline Points: 166 |
Mine girl has been put up for the season since the week before surgery. Wanted to get her out a few weeks ago but my wife talk me out of it. Was ask to go to the lake with a close friend for a few days, again she talked me out of it. I'm either getting soft or just protecting my knee.
67 ski nat
Platinum Member Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1184 |
Hope you’re all well
Last run of year at Sonoma heard a load noise, bent pushrod, blown head gasket Heads off, really bad cam wear , rust on walls So apparently original 50 year old engine never rebuilt I’m excited about new motor or rebuild. Should run much better cooler All good. Have good fall |
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Online Points: 3601 |
We had 93* last Thursday so we got the boat out for one more ski trip. Taught an old friend to ski, he tried about 10 times and got up on doubles. The smile on his face was priceless. Still had the boat on the drive on Saturday, we were hit with a very unexpected rain storm. I drained almost 40 gallons of rain water out of the boat. Put it in the garage and ran fans for 3 days to dry it out again. Got it cleaned, waxed, winterized and all covered up for winter. I hate doing this job, it signals our Summer is OVER. We found some good water last week and it was fun. Got to make my first cuts as a 66 year old! They were not that impressive but it was great to still do it. We cut it close on the last trip, it is 46* this morning one week later.
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 889 |
you may have a PM,,,
1994 Ski Nautique "Riot"
Faceplant
Senior Member Joined: July-27-2013 Location: Otter Lake , Mi Status: Offline Points: 406 |
Last ski was a week ago. Boat is in pole barn. Last Superjet ride was probably today. Still on hoist so we will see.
OK, I will bite, what is a superjet?
1980SN2001
Groupie Joined: August-01-2022 Location: Rocklin, CA Status: Offline Points: 96 |
MrMcD, since you are in close proximtiy to me do you winterize your boat every year? If so do you use anitfreeze? I keep mine in my garage but its not heated and I am wondering if I need to winterize using antifreeze. This will be the first year I've had this boat completely together so I am interested to know what others are doing in the Northern California Sacramento Valley area.
1980 SN Project
Years ago we had a freeze that broke the block in my neighbors boat. I always drain the block prior to winter and I had no damage from the exact same freeze. Low temps are rare for us but it can happen. I have never added antifreeze, just drained the block. Right or wrong, don’t know for sure but in 40 years owning boats I have yet to freeze one in our climate. If you pull the drain plugs have a 16 penny nail or something similar with you. Many times you pull the plug and no water comes out due to rust build up. Poke out the rust with the nail and out comes your water. If doing this you will need a back splash of some type, I have a 2’ x 2’ piece of thin plastic that I use to divert the water down into the bilge because it can splash out onto the carpet. The rust in the water can stain the carpet so be prepared to channel the water to the bilge and keep your carpet clean. You will get a lot of water draining. Seems like well more than a gallon at least. Good Luck.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10709 |
It's Yamaha's version of a stand up jet ski or PWC or whatever good or bad names people have for them I can't decide from MrMcD's post if the only thing he drained was the block or also the exhaust manifolds and the transmission cooler, but if you drain everything as your first step, it's pretty hard to screw up in your climate. A little RV antifreeze to mix with any residual water is a little extra protection. The right hand side of the block has the drain under the #1 spark plug area and with your engine at a 15 degree or so angle, there's gonna be some trapped water back by the #4 cylinder that has popped more than one person's freeze/core/casting plug over the years (or broken the block) Here's a thread in the link below with words and pictures courtesy of TRB, showing the drain points for a 351 PCM engine PS.............Most everybody has their own "best way to winterize" that's better than anybody else's, but like mentioned draining as the first step makes it a lot harder to screw up your engine
Everything must be good, it's fall and there's a winterizing discussion and the thread has gotten off track like most CCF threads do
desertskier
I just did the same but I used the flattened carton from the Coors Light 30 pack we just drank.
92 SN - Owned since 93
^^^Now we’re talkin’
67 ski nat
Excellent suggestion
I like the 18 pack, sturdier and longer for painting Recommend Walmart isle before the Rotella. |
After drinking all 18 beers would this job be easier or harder?
67 ski nat
Um. You and mourning wood helped me….remember??
I had to redo everything over in mourning |
Good One, With less beer I might have remembered. As I think back, It could have been the Whiskey, could have been the Gin, could have been the three or four six packs I don’t know but look at the mess we are in!
From an old song we used to sing and laugh about on camping trips while drinking around the camp fire, Great old song though,. Copy for you to enjoy. The words still crack me up but I am easily entertained. |
Morfoot
Water temp is still in the 70's here on Lanier. Got Day #97 for 2023 in on Friday before we dropped the course possibly for the year. Supposed to be in the 70's today so the course may be brought back up or we'll decide to bring it up or just free ski for the next month. Temps dropping to 31'F on Tuesday so its gonna chill the water off for sure put that's what wet suits are made for. Hate it for you northerners.... Just another reason why I love livin' in the south.
pjsmoreno
Knee is coming along really well in the last week. Probably due
to going back to work. Still dealing with soreness and tightness around the knee
area from the muscles and tendons. Little progress each week. Here in the Midwest and being laid up from surgery, I've
been building fires in our fire pit in our backyard. My ski buddies have been
coming over and making fun of me for what I've been missing on the water. I
just tell them to wait till I get back to cutting it up next summer. Now that the
weather has changed drastically in the last 10 days or so, the fires are in the
fireplace inside our home. It’s family time now. Last winter season I redid the boat hull by removing the UV
damage by wet sanding and replacing all the decals. That project took longer
than I expected due to all the unexpected “other” projects that came up, it was
well worth the time. Glad it’s behind me
though. But that pushed my normal winter hobby’s back a year. One of
them is usually wood working. Have a couple of projects I do need to wrap up.
One I have been sitting on for almost 3 years due to a major screw up on the
shaper table. I actually walked away from wood working since that has happened
but now after I had plenty of time to think it through on how to adjust the
project to repair the problem, I’m ready to get back into it. |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4237 |
Just so you're aware the Coors Light will keep the block from freezing down to about 22 degrees F but below that you need to mix in a few fifths of 5 O'clock vodka.
1980SN2001
Thank you MrMcD and KENO for the info!
1980 SN Project
MourningWood
@1980SN2001
Pardon my ignorance, but could you decipher for me your "handle"? ( didn't the 2001 model first appear in 1982? ) Is there a good story here?
From an earlier thread of his
And in case you missed the earlier thread it's in the link below |
1980SN2001
KENO is spot on and so quick! I wish there was a cool story but it was just that I was unfamiliar with the model of my Ski Nautique when I bought it. I joined this site shortly after I purchased the boat and just came up with the first username that came to mind. After reading a lot on this site I realized my mistake and I felt a little foolish about it and still do.
1980 SN Project
63 Skier
Nothing to feel foolish about, the various models and years offered and hull types/styles are pretty hard to keep straight. I think there's about 5 people on this site that really have it all nailed down. Years for the 2001 and Tique are joined by which years for which Sport Nautique hulls, which hulls are TSC 1 or 2 or non-TSC, was a Mustang the same as an American Skier, when did a BFN turn into a v-drive, on and on. |
MourningWood
Thanks all for the explanation. Amusing, actually.
I made the mistake of choosing what I thought was a 'play-on-words' forum name in Mourning Wood, intended to reference the 'loss' of wooden boatbuilding via the Dunphy. Mourning, not morning. Oh well..... Sorry to help hold the rudder in an off-course vector... |
With the aging process, there are other types of wood to be mourned...
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3889 |
I want to winterize but I am not sure which oil to use and which Fram oil filter to use. Also, do I pour in the antifreeze into the engine, or do I let the engine suck it in?
Confused.
