carpet gluing ? |
dans
Senior Member Joined: March-23-2006 Location: United States Status: Offline Points: 187 |
Posted: October-17-2006 at 6:45pm |
I have read all posts, but I still need some advise on spreading the glue on the floor.Did you guys spread the glue over an entire side and lay the big carpet floor piece down.Or just lay the big carpet piece down without the glue and lift it up a small part at a time the put the glue under it.Also,what is the best way to seal the floor after sanding ? I was thinking about West systems epoxy and paint it over everything without a thickener. Thanks for all the tips on removal , cutting, carpet type! Dan
65 'cuda
Get a roll of red rosin paper to make a pattern of your floor. Transfer the patern to the carpet. Cut the carpet to fit, leave it a little oversize for final trimming later. Fold half of the carpet back onto itself and spread the adhesive with your notched trowel. Let the adhesive tack up and slowly and carefully roll the carpet back onto the adhesive, bedding it down as you go, ensuring no wrinkles. Now fold the other half back onto the glued down side and repeat.
I put three coats of epoxy on all surfaces of the floor (especially the edges) The first coat was thinned 15% with acetone to help the wood soak it up. |
dans
Thanks Gary ,great idea. That's how I will do it.Dan
marks
Groupie Joined: April-23-2004 Location: United States Status: Offline Points: 96 |
dans,
If your floor is still bare, consider using Clear Penetrating Exopy Sealer as a primer under the West system's epoxy. Another fourm member recommended this to me when I was working on my floor. The stuff is about the consistency of diesel fuel and will deeply penetrate the wood. The best price I found for it was from rotdoctor.com |
behindpropeller
When I redo my boat I am going to put snaps in and snap the new carpet in the floor. That way I can take it out and get all of the sand out of it.
dans
I'm done.I did it like 65 'cuda said.The epoxy made it super hard.If I ever do it again I might use contact cement,not as messy.Thanks for the help.Dan
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21115 |
Dan, did you use the epoxy to attach the carpet? I dont believe thats what Mark and '65 were recommending- I think the epoxy was meant only as a sealer for the new floor. I will be using indoor/outdoor carpet glue when I put down my carpet.
dans
Yes , I used the outdoor carpet glue after I sealed the floor..I cleaned up the drops I spilled with mineral spirits & a rag.
