Water from main drain plug while on trailer? |
erm
Newbie Joined: June-20-2021 Location: Kamloops BC Status: Offline Points: 3 |
Posted: June-20-2021 at 9:58am |
Hi, 2005 Air Nautique SV211 removed from lake Yesterday. Trailered 1 km to house where it sat overnight on trailer. Next morning drain plug removed and cover installed in anticipation of long journey. Half an hour later, nobody near the boat and seemingly nothing to trigger it, about 3-4 liters of water came gushing out of the main drain. What could account for this? |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4234 |
Not familiar with SV211 and what drains into the bilge, but if a cooler or ski compartment had water in it, and weepholes plugged, they may have decided at that moment to unplug and drain into the bilge. Same if you have a leaf or something blocking the drain hole, a few liters doesn't have enough flow to flush it out right away, may have cleared the drain at that moment. Was it the stern drain plug that you removed? Or in hull T-handle drain? Again not knowing the boat, I'm assuming there is both.
erm
It was the t-handled drain plug just in front of the engine accessed through the floor door in front of rear seat. Thanks, newbie here so much appreciated. |
63 Skier
I know you said the boat is covered and ready for the trip, but maybe take a look in the bilge to make sure no more water trapped there, and if you want run a hose in to make sure the drain is clear. Or I suppose just look in the drain hole from under the trailer at a minimum.
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3888 |
My 2002 Sport has two drain plugs. On tee handle under the engine and one brass plug in the transom. Near the exhaust outlet. This is the plug I use when I use the boat. When I pull it out of the lake, I remove that rear plug and if there is any water in the bilge it comes out while on the ramp.
Your rubber and your drive shaft have a packaging that might be letting in water. Those two packings may need to be adjusted. Typically, it is the drive shaft packaging that can be the issue. Sounds like your drain was plugged that the water finally forced the blockage away. |
