ENGINE CUTS OUT |
DAC 207
Newbie Joined: October-07-2018 Location: Maine Status: Offline Points: 8 |
Posted: August-25-2019 at 11:57am |
Good morning,
I am the new owner of a 1998 Sport Nautique with a GT40 351w. We went out to ski and the motor will start and run for about 3 seconds then stop. For the 3 seconds it runs fine then quits. I am unsure of the maintenance record for this boat but I do not think the prior owner was hot on preventative maintenance. I would love a push in the right direction to find the problem. Thanks, Doug |
You could start with a search here. Correct Craft Fan gt40 trouble shooting. LP pumps are problematic.
Or you could start by checking your anti siphon valve it is where the fuel line of the boat connects at the tank. They have a check valve inside that can get clogged. Then you can check the filter and see if there is any junk in the FCC or even fuel in there. LP pump transfers fuel from the tank to the high pressure pump in the FCC and have had issues. Most just replace but at 200+ for a genuine PCM one or approx 80 from a Carter vendor (P 4389) you can pull yours apart to check it- |
DAC 207
I will be taking down the FCC tomorrow. With the 2 second consistent shut down period it my be a lack of PIP shutting down the fuel pumps.
Doug |
DAC 207
On the agenda for today is to break the fuel like to verify output from the low pressure pump and if that is good open the FCC.
Thanks Doug |
Just put a pressure gauge on it that will tell you if your getting fuel.
NCH20SKIER
Grand Poobah Joined: December-16-2004 Location: United States Status: Offline Points: 2205 |
Be prepared for a struggle with the FCC removal. Mine was. 2 person job to ensure the mounting bracket was not damaged while unscrewing the canister
'88 BFN |
DAC 207
Thank you for the insight. The canister came off with a 20 inch pipe wrench and steady pressure.
Wtrskior
Groupie Joined: April-23-2017 Location: Canada Status: Offline Points: 44 |
Rule out the safety lanyard/kill switch before doing anything else imo. They are prone to failure and power the fuel pump.
2001 Ski Nautique CB w/ GT40
DAC 207
It was the high pressure fuel pump. Cycled the kill switch to prime the system after putting all of the fuel system back together. Twisted the key and it made such a beautiful sound.
Thank you for all of your insight Doug |
DAC 207
The boat ran well for another day then stopped again, same symptoms. It would run for two seconds then stop. Reading back through the post the kill switch was mentions as being a trouble spot. My assumption was that the hill switch would be an on or off function not a failure that would allow the engine to fire up then quit. Evidently not the case. bypassing the switch made the problem go away. With luck we will be skiing for another month before it gets too cold.
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Online Points: 3593 |
Glad you have it fixed.
Does anyone actually use the Kill switch as intended? I will be honest, I have never used mine and frequently think of taking it out due to known failures it may cause. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10653 |
Quit thinking, just do it |
Sounds like a plan since it has not been used properly ever. Why leave it to a future failure?
Mark |
