Key pad problem |
klinderborg
Newbie Joined: July-17-2006 Location: United States Status: Offline Points: 6 |
Posted: July-17-2006 at 5:26pm |
Hi I have a 2000 Supersport and am having a problem with my keyless ignition. When I enter my code I see the indicator LED blinking as it should, but the ignition doesn't "wake up". I know I'm entering the proper code, and the battery is at full power. Has anyone else run into this problem and what is the fix?
Ken |
jkemper
Newbie Joined: March-08-2007 Status: Offline Points: 1 |
Ken,
I am having the same problem with my 2000 air nautique. How did you fix your problem. Thanks. Jkemper |
87BFN owner
Use the original code hard programmed into it from CC. Then reset your code. For some reason the computer is not accepting your code. If your not the original owner call CC with your serial number they should still have the code.
klinderborg
"J" I at first ordered a new key pad ($500). When that wasn't the problem I was able to return it to the dealer. Ultimately I had to send the "black box" mounted on the fire wall to the dealer. They "flashed" the memory, and returned to me. After that it worked perfect the rest of the year.
Good luck Ken |
9360SAN
Newbie Joined: August-31-2006 Location: Hong Kong Status: Offline Points: 23 |
I worry one day my keyless will fail even now is ok, any gentleman know how to connect a by pass key switch fow starting? for 01SAN.
Go on wakeboard
klinderborg
Forget about the bypass switch. I asked the same question. The dealer says everything electrical runs through the computer (black box), so a bypass is not possible.
Ken |
87BFN owner
Seems like everything now a days is controlled by the magic box.
So reme,ber if you mis treat the box your fun is all done. |
