  New Posts New Posts RSS Feed - 1999 SN EFI Question
Wormcat1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wormcat1 Quote  Post ReplyReply Direct Link To This Post Topic: 1999 SN EFI Question
    Posted: June-05-2015 at 10:41am
What would cause my red fuses to keep tripping on my 1999 SN EFI Box? Sometimes have to reset them 2 or 3 times before boat will start?? Maybe a bad fuel pump or something is clogged? Thanks for any help....
jhersey29 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2015 at 10:49am
Red.fuse? Do mean circuit breaker on the back of the motor? Which one of the 3? It only trips when the starter is pulling amps? If that is the case I would check all the wiring to the starter. Possibly a short.in the starter or faulty starter wire.
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2015 at 11:04am
Look for a loose connection and or corrosion at starter/breaker/solenoid.
Bri892001 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-05-2015 at 12:34pm
According to Joel, 11 posts down in the following thread, a partially failing low pressure fuel pump can start to draw too many amps, which will trip the 15A breaker:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=25584&PN=1&title=poor-mans-gt40-diagnosis
