Hull I.D. Location |
captinr
Groupie Joined: February-01-2006 Location: United States Status: Offline Points: 45 |
Posted: May-18-2006 at 10:01am |
Picked up our '68 Mustang last night and brought her home. I cannot find the hull i.d. number on the stern. My other three CC's had the id in the upper right corner of the stern but the '68 is smooth in that location. Any ideas?
DrCC
Hi captain,
Look on top of your engine stringers. Should be an aluminum plate with your numbers stamped. PS St. Wheel should be there today. Thanks AT |
bkhallpass
Yep, Dr. CC is right. The older boats did
not stamp on the stern. Should be and ID plate as he mentioned. BKH |
Livin' the Dream
Tim D
Look on the stringer, just in front of the motor mount on the passenger side. It should be a M with 4 numbers. Someone could have covered it with the flooring.
Tim D
captinr
There is a number M2321. Is that the whole number? I am used to the CTC.........
If that is the complete hull number, how do you tell what year the boat is? Thanks all! |
Tim D
Mine is a '66, and the number is M1924 or something like that. I emailed a guy at CC and asked how many boats they made that year, and he told me to give the serial # and he could give me some information, but I never got back to it.
Tim D
Tim D
A friend of mine has a '66 CC American Skier, which is almost the same boat, he has a bench seat across the front just like the rear, and his number starts with an A. I can't remember, but the numbers are close to mine.
Tim D
bkhallpass
Captinr,
Since 1972, the hull id numbers have been standardized across the industry. As I understand it, prior to 1972, it was kind of up to the boat companies. Below is an explanation of the post 72 ids. For prior dates, I think you're going to need to call CC with the seiral number to get a date of manufacture. BKH For post 72, you will find the Hull ID Number on the right side of the transom, just below the rubrail. For boats made in the US between 72 and 84: 12 digit code Example ABC 12345 1272 - First Three Digits are manufacturer code - Next five digits are serial number - Last four digits are month and year for date of certification. This is not the model year, but the date the boat was made. Alternatively another code was used between 72 an 84: Example: ABC 12345 M73E Last four digits indicate model year with last digit representing month made as follows A - August G - February B - September H - March C - October I - April D - November J - May E - December K - June F - January L - July Boats made after 84 use the same code used today: Example: ABC 12345 A900 First three - manufacturer code Next five - serial number Next letter - A through L, corresponding to January through December. Next digit - Year boat was made Last two digits - Model year of the boat. |
Livin' the Dream
southwind19??
Newbie Joined: April-03-2007 Location: United States Status: Offline Points: 22 |
dose anyone have the CC e-mail?? my Ser number is SW1035
UUUmmmm HEY guys....whats THIS do?? If you start your sentence with UUmm....you probably don't know what your talking about
