2 Questions for the boat boys |
MustangMadness
Senior Member Joined: April-15-2014 Location: Seacoast NH Status: Offline Points: 114 |
Posted: October-10-2014 at 5:28pm |
In replacing my shaft (stock 1/40) I discovered 2 things: the original seemed to have drilled indents where the set screws fell on the coupling and I had a castle nut on the prop where the new method is to use a nylock with cotter pin on the end of the shaft. I replaced the stock federal with a new 1210 ACME. The new ACME's hub is 2 3/4" wide and the federal is 2 3/8".
To make a long story short, should I pre-drill indents into the shaft for the set screws and how do I get a cotter pin hole to end up where the new nylock ends which is quite a bit further out on the shaft thread than the castle nut ended. The shafts are exactly the same length. |
I like a 6' beam on a small lake... My Muscleboat
1975 Mustang 225 307RH |
SNobsessed
I doubt very much that you will find the indents while pushing on a rapidly cooling hot coupler. If you really want them, I would drill them after you have the shaft & coupler assembled. (carefully drill through the threaded holes). It doesn't take much of a drill point to hold the screws, they are kind of redundant anyway.
Supposedly, you don't need a cotter pin with nylock nut. Just don't use the nylock nut too many times, it looses a little grip each time. |
MustangMadness
So I don't need the set screw indents or a cotter pin?
Thanks! |
SNobsessed
Cotter pin is not needed on a NEW nylock nut.
On the coupler set screw indents, I was wrong to imply you don't need them at all - as the OEM design came with them. |
