proper steering wheel removal |
illiniball2000
Senior Member Joined: June-27-2014 Location: Elgin,IL Status: Offline Points: 386 |
Posted: September-16-2014 at 9:41pm |
Can someone tell me the proper way to remove this steering wheel from a 71 Baracuda? I don't want to damage it.
Thanks |
Take a real close look where that center cap meets the hub you will see a wire clip,much like a circlip. Pull it out with a small screwdriver or a sharp awl. Once that's out the center cap will come off and you'll see the hub and the nut.
illiniball2000
OK thanks I knew there had to be something I was missing.
illiniball2000
Gary
It took less than two minutes to remove Thanks again |
