Full Seadek Floor Install on 1999 SAN |
Post Reply | Page <12 |
skutsch
$1200 or even $2000 is probably way more then carpet, but a reasonable spend to get a finished product as above. IMHO.
phatsat67
Jared, for the fellas doing stringer jobs (me included) do you think it would be a good alternative to paint the bilge and floor area with this paint vs. Gel coat?
Tim prefers Gel and I agree but if this were a little easier to work with maybe even brush on? It may be a little easier to handle than a gel spray out. |
Why cant you brush gel? I have. Lays down pretty nice.
scarbs
Groupie Joined: November-10-2009 Location: Arizona Status: Offline Points: 70 |
The product I used can be sprayed on or rolled on. I rolled it onto everything over two days. The cost is about $125 per gallon and I used all of three gallons. But I also coated a lot of extra stuff like the top and bottom sides of the three floor panels mentioned in my original post as well as the bow-filler step. Plus I applied it to the gunwale shelves/cupholders, and everywhere under the bow, helm, and observer's seat. The gel coat quotes I obtained while researching the project were about $400 just for the top side of the floor. As for using it on stringer projects. I wouldn't hesitate as it is easy to apply and would provide a waterproof coating. But you'd have to prime the wood before applying the urethane and it is NOT smooth. It has an orange-peel finish. But I, admittedly, am not familiar with how easy or hard gel coat is to apply or work with and I am not sure if this urethane is better or not. |
Not sure what youre envisioning for use on a stringer project... bilge coating maybe? I cant imagine it would be good for anything beyond that. What type of primer/prep did it require? Does it seem to hold much dirt? I know Joe said his bedliner bilge is hard to keep clean.
Gel could have been rolled just like the urethane at ~$40/gal and you can tint it yourself, FYI. |
scarbs
The urethane coating does not hold dirt and is easy to keep clean. Most anything brushes or wipes off as it would/does from the gel. I used an epoxy primer, but there are other less expensive recommendations for primer on the manufacturer's website.
I know that there are many out there who could do this project better and for less money. This is just the option that I chose for the reasons that I mentioned (most notably its toughness as it will not chip or scratch like gel coat) and it worked out fantastically well for me. I could not be happier. |
phatsat67
Ahhh, didn't realize you could roll it Timmy. I was thinking bilge coating.
correctboat
Newbie Joined: April-14-2018 Location: Canada Status: Offline Points: 1 |
2005 ski Nautique 196
your boat looks amazing and inspired me to replace the carpet with sea dek you used UHMW for taking up the gap created with the removal of the carpet around the hatches and floor pans UHMW is so slippery - did the Sea Dek adhere to it? How did you blend the UHMW in were you able to paint it or did you coat it with fiber glass first would you use another material if you had to do it again and if so, what and why? Thanks Robert |
