Mobil 1 10w40 question |
Author | |||
JPASS
Posted: October-29-2013 at 4:16pm |
I was looking into some Mobil 1 10w40 synthetic oil for my next oil change and I am finding their high mileage synthetic is the only one that comes in 10w40. The normal synthetic that I use in my cars does not come in 10W40.
Is this what everyone is using if you're using Mobil 1? |
'92 Correctcraft Ski Nautique
No. You should be using 15w50 if you want to run M1. The 10w40 doesnt have as much zddp.
Mobil1 Product Guide |
JPASS
know a place where I can get any (5qt container)? Doesn't seem to be available at any of the stores like AutoZone, Advanced Auto, WallyWorld, or NAPA when I checked online.
Nautiquehunter
Platinum Member Joined: December-31-2008 Location: Lake Lanier GA Status: Offline Points: 1010 |
I use Mobil1 15w50 in all my boats . For the reason TRBenj posted. Wall-mart has it for 24.99 5 qt container.
TX Foilhead
Wallyworld is the only place I've ever seen it in the 5qt jug. They stopped carrying it here for a while, complained to a friend who is a store manager and it came back. Turns out he likes it too and was pissed when they took it out.
Dreaming
if it's not available in your area, you could order it online. I would guess Rock Auto, Amazon, summit, jeggs or other online retailers would ship it to you. you'd have to plan ahead for that, or you could find something local like the VR-1 20-50 that has been discussed previously. The Rotella oil that I used in my diesel is also available at the local distributors too. That might be another option if the ZDDP levels are still current.
JPASS
I checked online at wallyworld and they were sold out of all mobil 1 oil. The message on the site states it's not available in my local stores. I'll go check in person.
Jeggs and Summit don't carry Mobil 1, only Royal Purple (which I would consider). Who knew this oil would be so elusive??? |
89Martinique
Senior Member Joined: September-05-2011 Location: Binghamton Status: Offline Points: 457 |
I have been running 10w-30 Mobil 1 for a few years now and have had no prob.
Current Boats:
1992 Supra Comp-TS6M PCM 351w HO Pro Boss Pro-Tec Ignition - Full Composite (no wood stingers!) 1989 (3rd Gen) Correct Craft Martinique B/R PCM 351w Power Plus 1984 E-Scow Keuka Lake, |
How about VR-1? Alot more powerful engines than yours are running it here with no problems. Easy to find,even Autozone has it. When was the last time anyone lost an engine using a quality ZDDP oil no matter what the brand was due to the oil being used?
89Martinique
Does wally-world sell Mobil 1 5qt for $30 with Mobil filters? My local Advanced always has that stuff on sale. Pretty nice, I buy it just to have around...
Current Boats:
JPASS
I thought it needed to be at least 10w40? Wouldn't 10w30 be too thin? I have three cases of Mobil 1 5w30 at my house and it is easy to find locally. I just was hesitant to use it because the manual stated the motor needed 40 weight. |
JPASS
Is the VR1 synthetic? I noticed they make 3 different versions: regular, race only, and synthetic. I'm assuming you were referring to the synthetic. I'll have to make some calls today to see what the local stores actually carry as opposed to relying strictly on their website. Ideally I would like to go with the Mobil 1 15w50, but I just have to find it locally first. |
Did you look at the link I posted above? The 10w30 m1 doesn't have the required zddp either. I know it can be hard to differentiate good info from bad sometimes, but all the facts are right in front of you. Same story on the m1 5qt jugs at walmart here... Went away for a while but now seem commonplace. You can go synthetic with the vr1 if you want to but the conventional is also very good. |
gun-driver
I got tired of running around trying to find the right oil every time I wanted to change the oil. So now I go to my local NAPA and order a case of VR-1 20-50, pick it up the next day and when it is about gone I order another. PROBLEM SOLVED
JPASS
I saw your link, I was simply replying to his post. I have been using Mobil 1 since the mid 90's and use it in everything I have ever owned. He stated he used the 30 weight with no problems and my concern was not with the additives, but with the weight. Previous owner said he always used synthetic and I am a little hesitant of switching to Dino oil after having run synthetic for so long. Motor has 1600 hours on it. Ideally I would like the 15w50 if I can find it, but unfortunately I am having a hard time with that now. The Valvoline may be easier to get. I just have to make some calls today to see what is available locally. I do believe I can get Royal Purple locally as well, but not sure how good it is for my motor in regards to the additives.. I hear and read good things about RP, but have never used it personally. |
JPASS
Success. Found it at wallyworld in the next town over. They have 5 jugs left. I'll be sure to pick up a couple when I go after work.
phatsat67
I like your style Paul. Keep it in stock haha.
89Martinique
What is the required ZDDP? the 10-30 has i think 900 PPM. Also, CC oil pressure: Cold - 70~75 psi, warm 25~30psi, after long run 15~20 psi then after idle for a few min comes up to warm, after long hard run (tubing) 10 psi... with a low idle of 400 rpm...
My Supra, Cold- 50 psi, warm 40 psi, after long run 35~40 psi, after run really hard 30 psi for short while... with an idle of 600 rpm.. How can the same motor have such different oil pressures on the same oil??? |
Current Boats:
Internal clearances (bearings, etc) will dictate oil pressure.
1200ppm of each zinc and phos is what I've read to be a safe level. |
89Martinique
1200 ppm.... oh... Guess I better switch my oil at the next oil change... Comp is due next year, the CC is good till 2015...
Current Boats:
ryanibanez88
Senior Member Joined: July-22-2011 Location: Midland TX Status: Offline Points: 219 |
anyone have any suggestions or is it just to thin
10W30 Amsoil Z-Rod Oil synthetic = 95,360 psi zinc = 1431 ppm phos = 1441 ppm ZDDP = 1400 ppm |
Ryan
1997 Ski Nautique Midland Texas |
a0128
Senior Member Joined: May-05-2014 Location: Oregon Status: Offline Points: 226 |
I run Valvoline 20W-50 Racing VR1 in my GT-40. Ryanibanez88- you will need a similar oil to meet the zddp requirements for your era engine. Given we all change our oil every 50 hours, I wouldn't spend the extra for synthetic.
Unfortunately not available in 5 qt sizes. Amazon has 6 qt case for $32.64. Prime members get free shipping. |
ryanibanez88
I have a case of the AMS Oil 10-30 should i not use it will it hurt anything ive read our engines need 1200ppm zinc and 1200ppm phos this 10-30 has 1400 of each but will it still be too thin
Ryan
samudj01
Gold Member Joined: March-10-2009 Location: NC Status: Offline Points: 933 |
Is castrol gtx 20w50 good enough?
ryanibanez88
its really low in zinc and phos needs 1200+
20W50 Castrol GTX ,API SN conventional = 96,514 psi zinc = 610 ppm phos = 754 ppm moly = 94 ppm |
Ryan
a0128
Thanks(1)
According to PCM Owner's Manual either 10w-30 or 10w-40 is acceptable.. Manual I would probably run 10w-40 given your Texas location and the summer temps. |
a0128
Not for your 1999 Sport. You need zddp of at least 1400. |
ryanibanez88
Thanks
Ryan
tullfooter
Grand Poobah Joined: March-02-2007 Location: White Lake, MI Status: Offline Points: 2225 |
+1 When I'm down to a case (6qts) I order 2 more. |
Play hard, life's not a trial run.
'85 BFN '90 BFN White Lake, Michigan |
Saw that the other day at our Farm and Fleet - since when is 6 quarts a case?
