Propeller for 90 SN |
roadkingpuck
Groupie Joined: October-05-2005 Location: United States Status: Offline Points: 61 |
Posted: November-16-2005 at 6:51pm |
We have a 90 SN that we use primarily in a slalom course. Engine is PCM 351, 240 HP, 1.23:1 tran. Our last time out we dinged the prop. So, we are thinking about getting a new prop in addition to repairing the original. What is the recommended prop for this type of boat when it is used mostly for skiing? The prop we use now came with the boat; not sure of the size/pitch.
You have a couple of good choices for new props. I would stick with Acme- most people seem to be very pleased with them (including myself).
I am actually in the process of choosing a prop for my '90 as well. We had good a good experience going from an OJ 4-blade to the acme 422 4-blade on our 92. They now have a 3-blade available that fits, so I asked them which they recommended. This was Acme's response: "The 422 12.5 RH 15.5 four blade nibral 1” bore .105 cup is still a good choice for your 1990 Ski Nautique. We do recommend the 470 12.5 RH 15 three blade nibral 1” bore .105 cup. When a person is interested barefootin. The 470 will give on the average of 1 mph more top end speed with no loss in hole shot + a bet better wake for skiing." In short, I will be ordering the 470 3-blade. If I dont like it, I can return it for the 422 4-blade, since I know that is still a great prop. As far as where to get it, check out deltaprop.com. With the discount code PNACME05 you can save an additional 5%. Its the cheapest I have been able to find them. |
ccskier16
Senior Member Joined: January-29-2004 Location: Hartland, WI Status: Offline Points: 103 |
The standard prop is a 14x16.
bkhallpass
Agree with TRBenj. 4 Blades were popular for a while, but with the new acme 3 blade, folks are going back to 3 (at least for the DDs)
On the V Drives, the recommendation still seems to be the 4 blade. BKH |
Livin' the Dream
roadkingpuck
Thanks for the info.
roadkingpuck
Talked to the folks at Acme. They recommended either the #612 (three blade) or the #422 (four blade); said both would be good for skiing. Does anyone out there have experience /opinion regarding these two props? Thanks
I spoke with Acme again as well. I asked how much the #470 (12.5 x 15 3-blade) differed from the #612 (12.5 x 15.25 3-blade). They said the #612 should be 1/2 mph faster on the top end, and the #470 would turn 50 RPM more.
Since I plan to modify my motor in the future I think I will try the #612. If you plan to stay at 240 hp, the #470 may be the way to go. I think both props would slightly outperform the #422 4-blade. |
bobby
Newbie Joined: December-01-2005 Status: Offline Points: 2 |
www.boarditup.com, a home business I think but Carl will hook you up and offers best price I have seen on Acme. Easy to return, no hassle. I just got a new acme 4-blade for my 92 Nautique Excel, couldn't get a 3 blade that fit right, and the 4 blade is encredible and super smooth.
92 Nautique Excel
02 SANTE |
