Poor Man's GT40 Diagnosis |
Post Reply | Page <1 678 |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10667 |
It sounds to me like you maybe just need to do a cable adjustment or maybe a cable end replacement The noise you hear would be the relays for the ECM and the fuel pumps and then the pumps running. When you do the wiggle or jiggle, due to the slop, you eventually hit a spot where the NSS is closed up and when you turn the key, the remote solenoid/relay gets energized and passes power to your most likely "perfectly good starter" The thread below has some good reading, it was talking about a Borg Warner transmission but all the same stuff applies to your PCM transmission and cable and linkage You want to be able to look at the cable end at the throttle control because they (both the throttle and shifter ends) can wear out like the pictures in the link show, They're not the easiest things to get to, but if an adjustment at the transmission end doesn't work for you, then you should look at those If you put both wires on the same terminal like mentioned in the previous post, and it starts, it doesn't mean that your NSS is bad, it just means that you took it out of the circuit and it could be good or bad. Your jiggling picks up the switch, so most likely an adjustment is needed. If you disconnect the cable at the transmission end and manually shift the transmission lever into the neutral detent and it starts every time, then the switch is good. And the kill switch has nothing to do with the power to the starter, it affects power to the fuel pumps and ECM but the engine will still crank over. You can start with adjustment and if all else fails, spend some money on the switch, but remember, you replaced it once before without curing the problem.
Sdunn4
Newbie Joined: May-15-2019 Location: Ticonderoga, NY Status: Offline Points: 9 |
Thanks for the replies! I’ll follow the procedure spelled out in the posts and links, assuming that connection of the 2 sides of the NSS gives me a clean start. I believe I did this years ago but never dialed the position in correctly at both ends of the throttle cable. Will let you know how it turns out tomorrow (cold winds and a chance of snow today!)
Sdunn4
Interesting development; I just connected both sides of the NSS together and tried to start the engine- no go. Jiggled the throttle back and forth a few times and it started right up. Any ideas for the next step?
Thanks! |
Sdunn4
An oddball idea- the DIM site has my switch called out (PMC # R153011) and it mentions it comes without the O ring which must be ordered separately. Hmmm- neither of my switches has this O ring. Could that allow the ball on the switch to ride just low enough into the indent so that nothing but “perfection” in the position will allow for a start when in the neutral indent location? I bet I can buy the O ring at my local hardware store . Your thoughts?
Sdunn4
I believe the problem is solved! Installed an O ring on the “new”NSS- which I had never had on there! Old switch in fact did have a (very compressed) O ring. Probably the “old” NSS was never bad to start with.
Tightened the throttle cable at the transmission location and had several repeat starts in a row! I think the decreased clearance at the indent with no O ring installed, along with a little slop in the cable were the culprits. Thanks for your help! |
Let's hope it's fixed.
The bypassing of the switch and getting no start earlier today doesn't make sense, but if it's starting now, "you done good" Or did I mean to say "you Dunn good" ?
