exhaust gaskets |
YooperSully
Senior Member Joined: August-07-2009 Location: Hancock,MI Status: Offline Points: 316 |
Posted: June-25-2010 at 12:33am |
I got a little maintenance package today. I was able to get the manifold gasket on but I wanted to replace the gasket for the riser. Is there a trick to getting the riser and manifold separated?
87' 2001
Chris4x4gill2
Senior Member Joined: August-25-2008 Location: Smith Lake, AL Status: Offline Points: 358 |
Should come off fairly easy once you remove the 4 bolts and the hose from the exhaust. if its stuck tap it with the handle of a hammer to loosen it up.
gun-driver
Grand Poobah Joined: July-18-2008 Location: Pittsburgh, Pa Status: Offline Points: 4117 |
More than likely the bolts will snap off. There are two that are around 4 1/2" long and two that are around 2 3/4" long.(cant remember exactly how long) The long ones almost always snap.
I was able to get some of them out by heating the outside of the riser with a torch(a real one not propane)and working them back and forth till they came out. The ones that snapped, I was able to get a pair a good vise grips on and with more heat and Pb-blaster worked them back and forth till they came out they came out. Re-tap the threads to clean them up and I used anti-seize on the new ones. I also take them out and apply new anti-seize every fall and have no problems with them rusting now. |
SNobsessed
Cleaning up the rust from the gasket surfaces in the riser joint is also a good idea. I just used a large file & kept it flat.
