GT40 conversion to carb |
Post Reply | Page <12 |
I think on my Summit shopping list I'd have
An intake manifold, Edelbrock Performer, Performer RPM, Weiand Stealth Carburetor mounting studs SUM G-1423 should be good An adapter plate SUM G-1420 if you're using an Edelbrock performer. It provides a wider seating surface for the carburetor. Intake manifold gaskets FelPro 1262 S3 work good A carburetor of your choice An oil pressure safety switch for the fuel pump. Holley 12-810 is easy to wire and works good. Your new LP fuel pump for the gt40 should work just fine supplying a carburetor since PCM used it for that purpose on some carbureted engines. Some marine fuel line from pump to carnuretor A marine distributor of your choice. If a DUI is your choice, it looks like you'll need a second choice because Summit's shipping dates on the DUI for your Ford all seem to be at least a couple of months away. You may need to talk to a human voice on the phone about this. They do have A Pertronix D231800 and you'd need a coil like a Pertronix Flame Thrower to go with it. You could shop at SkiDim or Nautique parts and pay way, way over list price for a DUI distributor if they have it in stock A flame arrestor, not knowing how much clearance you'll have between the engine box and your carburetor depending on manifold choice, the lower the profile, the better. What works on a Holley doesn't necessarily work on a Quick Fuel due to the external float adjustment screws on the Quick Fuel sticking up a bit. A little dimpling of the bottom of the arrestor sometimes helps. It's getting a little pricey, but does what you want to do............ like save your summer and let you go skiing And very importantly..............you will be Jonny's hero for actually doing this but only if you use a Quick Fuel and a DUI with a RED cap
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Online Points: 2870 |
JQ is watching this thread very closely.
macey
Newbie Joined: July-22-2018 Location: Ireland Status: Offline Points: 19 |
Have ordered all parts required to convert to carburetor. I'm sure there will be others who will in the future consider this change and possibly some currently who are considering it. I will leave an update of my conversion as and when it completes and report on how it turns out. Many thanks again to Jonny Quest and Keno who have been a great help. At current prices with top quality compnents the parts cost of conversion is pretty much exactly $2000.
Once removed I intend to have both the ECU and the loom tested, part of me would still like to diagnose the initial problem but at 22 years of age I would assume I will not refit the injection system. Will keep you posted.
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4248 |
I will also watch for your updates with great interest. Best of luck with the work!
BobinIL
Newbie Joined: July-29-2018 Location: Illinois Status: Offline Points: 36 |
I will be following this tread with great anticipation as well, my 97 sport GT40 has ben unusable for 3 years now due to the engine cutting out one warmed up. I have literally changed everything but the ECM. My local dealer has it now trying to figure out what is going on. I am so fed up with this thing that I would gladly convert it to carb if i would have a reliable boat again.
What dealer did you take it to Bob?
most don't seem to want to work on something over 10 years old. I suspect it's more like eats alot of time and not many have the experience or access to parts.
BobinIL
I took it to Liquid Edge in Farmer City. Doug is an old friend of mine and has made some progress. He has had it for about a month and determined that the HP fuel pump is getting hot and cutting out. It will continue to run with the engine cover up to aid in cooling. We are currently looking for restrictions in fuel flow. Possibly the return line.
The pump is cooled by the fuel flow. I suspect the pump is failing and the wires are what are getting hot from too much load. Fuel in these pumps flows right over all the moving parts. They normally do not get hot unless your fuel flow is restricted or you are out of gas. If these pumps are run dry, no fuel flowing they self destruct in a matter of seconds.
