'86 Silver, 350 GM Electronic Ignition |
JamoJones
Groupie Joined: September-13-2022 Location: Lee Center, NY Status: Offline Points: 50 |
Posted: July-20-2023 at 8:28am |
Hi All,
I picked up another project (as described in Gen. Disc.), and had it out for a ride the other night. All went well until it didn't. Cruising at speed, idling around, just enjoying the first ride. Anyway, idling along, it suddenly died...like you shut it off. No sputtering or anything, just died. I have fuel & air, no spark. It has 12v to the ignition module, which happens to be an Accel Super Coil, # 140003. I was thinking to just replace the cap, rotor, and the same Accel, but a fellow S/N Bud said I should be sure the P/O didn't install a non marine type ignition. So...any thoughts on what I have or what I should go with? The boat has only 504 hours on it and was running perfect at all speeds, top speed of 43 MPH. Other than our Canadian fog, it was a beautiful evening to be out, even the tow back by friends was as good as it gets. Just another adventure. Thanks...
1986 Silver Nautique #49 of 82
1987 Ski Nautique 2001 |
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Online Points: 3337 |
If the impedance of the coil was lower then the ignition module can handle, then the module will overheat, and fail entirely or during use.
there is no recovery after that, it will be unreliable. See if the module is switching, can be as simple as a test light. Getting a new, matched , module and coil might be in order Accel Super Coil, # 140003 is half ohm. unless the module is smart and current limited, its too much current for it. likely fried the module
JamoJones
Thanks GS,
The existing ignition module is older(?) GM # 990-5L11. I found the exact Accel 140003 w/matching cap & rotor on Speedway Motors. They also offer an Accel ignition module as "what others order along with the 410003" I would like to assume it would work with the above. But...is there a difference for marine applications? They do not mention that on their site. I'll call with questions before I order, but they're in the business of selling stuff. Guess that's why I'm here. BTW: what do you recommend for spark plugs? Thanks again...
JamoJones
Correction on first post...I should have said 12v to the Super Coil, not ig. mod....
With what you've written for part numbers, combined with the quote above, I figure your fellow SN bud is pretty smart. I'll guess that you have an Accel or some other companies version of the GM HEI distributor that got put in some time over the years. It's probably got a vacuum advance cannister hanging off of it..............that tells ya' that it's not a marine distributor. I hope I'm wrong If that's the case, replacing it with a marine version of the HEI distributor would be the safe, smart thing to do. Maybe you have a marine HEI with some Accel stuff in place of the original parts. If you know how to post pictures here, now's the time to post a few of the distributor from different angles showing any labels/tags on the housing itself. If you don't know how, read the thread about posting pictures in the link below. Read the last post dated 2/7/23 for posting pictures with a free IMGBB account. Or read your PM's and you'll find a phone number that you could text the pictures to and an e mail address that you could send them to EDIT... I found some pictures in your recent posts, but you have a PM anyways. If you want to figure out what your problem is, do a google search for "troubleshooting a GM HEI ignition system" and you can figure out if you have a bad module or bad coil or what your problem is. If you end up needing a marine HEI distributor, Jonny Quest is the unpaid, totally biased spokesman for DUI distributors here on CCF and another place or 2 also. We'll wait for his sales pitch. |
JamoJones
Thanks Keno,
No vacuum advance, the parts are zip tied together. The mechanical advance works, but is sticky, the springs don't return it vary well...just needs a cleaning I believe. I'll try to post a pic. Thanks for the PM, I'll be back to you on that...
JamoJones
JamoJones
Looks pretty automotive (AKA non marine) to me.
No vent screens ............... and .a pretty we'll just say "not too good job" of getting rid of the vacuum advance and blocking off the hole where it used to go through. It may work just fine after you fix the no spark issue, but it leaves you more vulnerable to an explosion in the case of a gas leak meeting the spark in the distributor They meet under the cap then you have the big bang that could be avoided with a marine distributor In the marine version, there's a little pop that has it's energy dissipated by the brass vent screen(s) Same principle as an old coal miner's lantern
Here's a picture of a DUI Ford marine distributor, you can see the locking plate that disables the vacuum advance and also around the inner circumference you can see the screen that covers 4 vent holes in the housing. Not shown is the rubber seal that seals the gap over the locking plate where the cap sits on it No zip ties either The vacuum advance is on opposite sides on the Ford and Chevy because they rotate in different directions and the weight arrangement is opposite from the Ford to the Chevy for the same reason.
JamoJones
Thank you, Keno,
I'm officially putting out a request for Jonny Quest. I'd like to talk to you about my problem. It looks like the best thing to do is to do it right and be done with it. Do you sell the DUI's? I did a search and found them, rather buy "locally" if I can. Thanks... |
Jonny's probably out in his new girly truck right now and won't see this for a while
The DUI part number is M12720RD for one with a red cap, a blue cap version would be M12720BL and a black cap version would be M12720 BK. There are other color caps too. You want a normal rotating distributor even though you have a reverse rotating engine. This is because the camshaft turns the same direction in a normal rotation Chevy and a reverse rotation Chevy, unlike Ford engines. It would make for a long discussion here, just say "I believe" He doesn't sell them, he just thinks everybody should have one. You may have a hard time finding one locally and even Summit, Jeg's etc have a delay for them to be shipped from DUI. Here's a link to the DUI website with the right part number selected Just remember, no RR gear needed or wanted and the only part number you want is M12720 with the color code after it like RD,BL, BK Phone calls might be needed to check on availability at different places
And..........if you're feeling cheap, don't want to wait for a DUI to be made and shipped, here's an alternative on Amazon
You can ignore any claims of huge power and economy increases in their advertising. They come from that big country on the other side of the Pacific. You could do some research on A Team Performance if you're interested I have no experience with this distributor, just thought I'd mention that it's out there
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2867 |
Girly truck, indeed. My husband drives it too!
JJ
I cut and pasted this quote from your other thread, just so somebody reading this would know what you did. Glad it worked out
