'94 SN 351 ProTec with carb backfiring? |
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 891 |
Posted: July-09-2023 at 2:59pm |
'94 351 SN carbureted with ProTec.
So, went to start after winter indoor storage. Battery fully charged, good grounds on batt cable. Backfiring out carb, won't run. From just sitting? Is this the beginning of the end for the ProTec?
1994 Ski Nautique "Riot"
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3607 |
Any chance moisture got into the electrical system? A little moisture can make the spark jump and cause misfires.
MourningWood
It stays indoors, covered. But I guess moisture is possible.
Before I rip out the ProTec and buy and install a conventional ignition system, are there any troubleshooting procedures that I can perform before tossing money and parts it? Thanks
I have zero Pro Tec experience to share. We may need to wait for Ken to catch this one.
MourningWood
Fingers crossed on that. Also, JQ you have a PM-thanks.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10734 |
ProTec and troubleshoot don't seem to belong in the same sentence here on CCF
People just wimp out and put a distributor in. If you e mail me at keno439@gmail.com I can send you a couple things I have that may or may not be useful A JQ PM, you must be wanting the RED DUI sales pitch
MourningWood
RESOLVED.
Cleaned a few grounds and ran the voltmeter around. Finally got around to battery test-50% charge. Charged fully-started right up-runs (on trailer) perfectly. In the end, I think it was a simple matter of low voltage causing spark scatter. To the Delta we go-thanks.
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2865 |
Let's hope she holds together!
Since it was a "simple" matter, there must be a simple explanation of how low voltage causes spark scatter, in simple words for my simple mind
MourningWood
Sorry, if there is a simple explanation, I simply don't know what it is. I was led to this conclusion by comments in this old thread I came across... Also, much thanks for the excellent ProTec wiring diagram which helped me test the 'hot' pins for voltage, etc. https://www.speed-talk.com/forum/viewtopic.php?t=45017 |
MourningWood
Great weekend on the Delta (HOT!). Boat performed perfectly.
I'll be keeping the battery fully charged! Thanks for all the help.
