Heater options |
ultrarunner
Platinum Member Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1810 |
Posted: February-25-2020 at 1:20am |
Hey folks, now that I'm back in the game, what's the latest on heater recommendations? This for an SN. Has anyone gone to the electric units, and if so, is an ALT/BATT upgrade required, or will stock do it? Or is the traditional plumbed unit preferred? Ideally, I'd have a big enough unit to run a hose to the rear seat in addition to observer and driver....Thanks, Ultra...
stepper459
Senior Member Joined: June-17-2007 Location: United States Status: Offline Points: 349 |
I'd be curious if anyone's had luck with an electric unit in an SN. I've had a few boats with the standard hot-water heaters and they're hard to beat. Get a 3- or 4-port unit and just run a hose to the back when needed. I had that setup in my old Supra and it worked great, although the air isn't as hot by the time it gets to the back seat - still better than nothing.
I'd also recommend a y-pipe near the water pump for the return line, it really helps with heat output at idle. If you don't know what I mean, it's a part that Heater Craft sells for that exact purpose. |
I think you'd have to upgrade the alternator they are only around 55 amps. That Y adapter made all the difference in my setup though,well worth it.
MACS81SN
Senior Member Joined: May-27-2009 Location: NW OH / S. MI Status: Offline Points: 109 |
To get 5000 btu at 12 volts would require a minimum of 125 amps. 5000 btu is about what one of those small portable room heaters puts out. From my experience, 5000 btu is probably half or less of what a hot water heater would provide. It would take a 200 amp or larger alternator to operate this along with the other electrical needs. Doable but not practical.
1999 -SN - 502 Python 1981 - SN Owned 33 years - Sold 1968 - Mustang - Sold |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4245 |
Definitely go with the plumbed hot water, and I"ll be 3rd to say do the Y pipe. Simple plumbing, no harm and no load on any engine component beyond the electricity to run the blower. Really one of the best upgrades I did on my boat, love having the heat.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21135 |
You can make your own y-pipe FYI. Just a tee with a restriction on the return.
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3893 |
The Timmy Tee gets re-purposed.
ultrarunner
I'm considering the 300 series so as to have an additional outlet to pipe some warm air to the back. Anyone have a mid-90's vintage SN like mine that you can post a pic of your installation?
Thanks, Mark |
63 Skier
I believe I bought the 300, it's a 3 outlet. I don't know the difference under the foot pad between my '98 Sport and a Ski, it was a very tight fit. I had to play around with positions and hose runs to make it fit. I have 2 of the retractable hoses, and one fixed vent at the driver's feet.
ultrarunner
Yep, 3-outlet. I'm wondering if under the observer couch would work, toward boat=center...I'd have to fabricate some openings in the couch base for hoses and to drop one at the drivers seat. Having the floor cooler and battery box there doesn't help vs. the Sport's layout on the floor for hoses and such...
63 Skier
I know 3 retractable hoses are nice to have, but I was glad I took one outlet and just made it a fixed vent at the driver's feet. Then the one hose can warm the driver or person in the middle jump seat, 2nd hose to the person in the passenger seat. I briefly thought about running a vent to the back seat, but nobody is back there when we are skiing so didn't seem worth the effort.
So if you do the observer seat base you need to leave enough flex to be able to lift the seat for storage, right? Not sure how that would look, am wondering if going to the port gunwale is an option. |
ultrarunner
Yeah, under the couch, as much room as there is, wouldn't be ideal for several reasons. Behind the drivers foot plate looks like a reasonable location...not much room to work, but this person did a nice job. I'd have to make a modification for the larger 300 series, but likely doable... |
