  New Posts New Posts RSS Feed - Question about GM 350 engines
nuttyskier2002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Topic: Question about GM 350 engines
    Posted: January-25-2007 at 9:25pm
Anyone out there ever tore down a 350 Chevy marine engine, say right around 92 to 95 year model. Specifically I need to know what type pistons are in these. Mine is carbureted and rated at 265 HP. It's a Mercruiser Magnum series engine. I'd like to know if these pistons are dished and if so what shape and cc volume of dish if any. Thanks! Brian
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2007 at 9:03am
would a 2004 help? i have a head off, call me, I'll look in my merc catalog, Eric
877-369-6693
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2007 at 9:13am
Nutty, they show from 1975 to 1996 using a dish w 4 valve reliefs, I have alot of low low hour sbc late style, stuff laying around,
if I can help you out let me know Eric,
got 2 full rooler cams, one from a 305 and one from a 350, one has 12 hours and the other has 30 hours.
backfoot100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2007 at 10:22pm
When I replaced the heads on my '86, the pistons were flat tops with four valve reliefs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2007 at 10:42pm
If you know the spec on any of them I may be interested Eric. Otherwise I'm going to go with a Comp Cams P/N 08-416-8. Specs are 212/218 @ .050 and .488/.495 (In/Ex). A cam with similar specs (except .010 more lift on both In/Ex) equiped with the intake I'm getting on an L31 Vortec 350 dyno'd at just under 375 HP @ 5100 RPM and over 425 ft-lbs of torque at 3900. Torque curve was very flat from 2500 to over 4500 RPM. I don't expect to get quite as good of results but anything close will suit me.
Former boats:
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2007 at 11:31pm
Originally posted by nuttyskier2002 nuttyskier2002 wrote:
.488/.495 (In/Ex)
Must be gross lift, correct? Which rockers does that a$$ume?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: January-27-2007 at 3:21am
That is max lift at the valve with 1.5 rockers. These engines ('87 and up) use hydraulic roller lifters which will tolerate higher lifts and a more aggressive cam profile.
Former boats:
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: January-27-2007 at 3:30am
877-369-6693
Do you still have the heads off of this one? My engine is a Gen I. Were they still using Gen I engines in 2004? I know that only
Gen III engines are available for automotive/truck use now. I thought it was the same for marine. Someone please correct me if I'm wrong.
Former boats:
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-27-2007 at 3:14pm
Yes I still have the head off, it had not quite 30 hours and dropped a seat, it does still have the cam in and I can figure out the part number and try to get the specs, do you have the old cam out? if so if you know the specs on your came i can measure the lobes and compare the 2 numbers thats if you knew yours lets say had .480 lift and a total lobe measurement and subtract from my total lobe measurement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-27-2007 at 3:20pm
Nutty, i can probably get these indmars for $200.00 (Exhaust manifolds) let me know if your interested. he was at $600.00 but then i explained to him when they were new 20 years ago they got big money for them because they were'nt common.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: January-27-2007 at 4:12pm
Eric, let me call you Monday morning about that engine with the head removed. I don't have mine apart yet, just collecting parts at this point. I plan to use the boat as is this spring/summer then do the project next winter. What advantage would it be to switch to Indmar manifolds?
Former boats:
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-27-2007 at 6:47pm
Well......they would be shiny, there is a picture somewhere on the posts and if your worried about weight these would probably knock 60lbs off from stock
    Eric
