  New Posts New Posts RSS Feed - '76 PCM 351 Help finding engine gaskets
sberard5 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sberard5 Quote  Post ReplyReply Direct Link To This Post Topic: '76 PCM 351 Help finding engine gaskets
    Posted: July-13-2015 at 1:59pm
Hey Folks,
Well, my engine is leaking oil. Primarily from the rear main seal. I plan on using the boat for the rest of the season and pulling the motor in the fall and going through it over the winter. I was wondering if anyone knew of a source for a complete engine gasket kit or a place to find them individually?
It is a 1976 Pleasure craft Marine 351 used in the same year Ski Nautique.
I'd appreciate any input you can provide.
Thanks guys,
Steve Berard
East Waterboro, ME
spiralhelix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spiralhelix Quote  Post ReplyReply Direct Link To This Post Posted: July-13-2015 at 2:03pm
Have you talked with Zach at n3boatworks? he seems to always have what i need (or at least can get it for me)
Spiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote sberard5 Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2015 at 10:02am
I will shoot him an email. Thanks
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2015 at 10:10am
Should be a two piece seal, just go to NAPA and get one, about $15.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2015 at 11:33am
I have in the past used a quality automotive set with no trouble,at least in fresh water. But Felpro makes marine sets now too. You can check them out at Summit Racing. I like the newer style of silicon gaskets used on the valve covers and oil pans rather than the older style of cork ones.
shierh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shierh Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2015 at 1:09pm
seal is reverse rotation,   it has hash marks in opposite direction
You can get everything from summitt racing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2015 at 1:17pm
Two piece seal has no wick lines, the crank has the wick lines. You can buy a marine seal, open it up and it will have the same ford number stamped in it as the one you could get from napa. Bought one from skidim back in '98, different package, same part.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2015 at 1:24pm
Agree with Tim. If the seal in question has wick lines then it may be a newer 1-piece seal and the block/crank may be newer (83+). 1-piece seal blocks have the wick lines in the seal and the cranks are smooth... Opposite for the 2-piece style.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sberard5 Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2015 at 1:43pm
Thanks guys. Won't know if the crank has/doesn't have wick lines in it until I pull the motor out at the end of the season. Thanks for the heads up though... Going to email Zach @ N3 and check summit racing while waiting for a response.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sberard5 Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2015 at 1:57pm
Running into a problem. For the life of me I cannot find Zach's email address. Anyone have it on hand?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2015 at 2:17pm
zach@n3boatworks.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote sberard5 Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2015 at 12:35am
Wow what a simple address. Lol. Thanks
