'97 Ski restoration - a few issues! |
Post Reply | Page 12> |
Goldcup101
Senior Member Joined: August-27-2016 Location: France Status: Offline Points: 104 |
Posted: September-10-2018 at 1:07pm |
Thanks for the explanation. I only bought the current flame arrestor last year and I see they want circa $90 for the one with 2 attachents so I feel a modification coming on!!
I read about the arrrestor not clearing the float adjuster in an old QF thread so I bought a spacer at the same time as ordering the QF carb. It's a bit tall but if I cut it down enough for the arrestor to just clear the float adjustment screw, I think I can still use the same centre attachment bolt. If I need to, finding a new (longer) bolt shouldn't be impossible. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10753 |
Earlier Holley carburetors didn't have the fitting pressed into the carburetor like your later Holley did.
They used a flame arrestor like what's in the picture with another fitting for the overflow sight tube from the fuel pump. You could buy one like in the picture from SkiDim or a variety of other places or modify yours if you confident that you won't defeat the flame arrestor function by doing it. Edit the ones Ski Dim sells won't clear the adjuster screw on the rear bowl since they sit flush with the top of the carburetor. Lack of clearance between the bottom of the arrestor and the external float adjusting screw on the rear bowl of the Quick Fuel can be a problem depending on the arrestor if you get a new one You could also put a fitting into the carburetor body of the Quick Fuel in the same place. ] |
Goldcup101
Another query - the pipe from the fuel pump that is normally empty of fuel unless the pump diaphragm fails, used to connect to a port on the 4160. There doesn't seem to be a similar attachment on the QF. Does anyone know where it goes?
Thanks! |
Faceplant
Senior Member Joined: July-27-2013 Location: Otter Lake , Mi Status: Offline Points: 407 |
I've had my QF for 3 or 4 years now . ZERO problems !!
Bri892001
https://www.summitracing.com/parts/rra-18-8115/overview/ I guess that's a few bucks, but if it didn't kink and you didn't have to spend all day bending metal fuel line, it's probably worth it. The next sign of any trouble with my carb, I'll probably go with the QF myself. |
Goldcup101
No, I found a link to this one in a previous quick fuel thread.
https://www.summitracing.com/int/parts/rra-18-8115/overview/ Summit was the cheapest I could find it but still seems a lot for a bit of hose with a connector on each end! |
Bri892001
Cool that the new Quick Fuel Carburetor solved it. How did you do your fuel line, did you bend your own?
Goldcup101
Installed the QF M-600. There was a chance here that it would make no difference and I'd have just wasted $500 but thankfully the boat is transformed.
I had a hunch it was a fuelling issue rather than anything else. Now starts on the turn of the key with no throttle required. No stalling, no flat spots and the acceleration is on another planet compared to what I had before. Also now gets to WOT (seemed to top out at 4200rpm before). Looks like it was money well spent! Got the Airguide working again, just need to get hold of a water temp sensor and speak to PP about the dufff gauge. I forgot it was labour day when I was in LA this week so couldn't get anything shipped in time - will have to wait until next visit stateside. Thanks for all the tips guys! |
Goldcup101
Great, thanks for the tips. Should hopefully get it fitted Friday when I get home.
That's the good gasket that Ski Dim sells.
It's especially important to have one of them between the spacer plate and the manifold to seal that area well. One of the same between the carburetor and spacer is good too. They'll work with the Quick Fuel carburetor. |
Goldcup101
Yep, that's it Ken. Many thanks for the info; looks like the coil is fine then.
Here's the gasket, will this do the job or do I need a special one with the M-600? Incidentally, I got a new fuel line as I gather the Holley one doesn't fit. I'm going to LA tomorrow so I'll get priority shipping for anything else that I need. (Like a water temp sender as I have just discovered!) Looks like a boat project is never finished! Thanks guys, Calum |
SNobsessed
You might want to post a photo of the gasket. Some fit but not wide enough & eventually leak. Ken will know just by looking at it. |
You have the Prestolite breakerless distributor assuming it's the original. it uses the same coil as the Prestolite points distributors but the ballast resistor is removed from the wiring. PCM's part number is R117001 and the description in their parts manual says "coil breaker point ignition" (used with breakerless distributor without inserting a resistor in the system) It's a 1.5 ohm coil that needs no ballast resistor when used with their electronic system but if used with points you need the resistor before the coil to make the points last longer. 12 volts to the points would burn them up pretty quickly. So.............if you have a 1.5 ohm coil you should be just fine even if it says to use with an external resistor. That wording if for use in a points system. Here's a picture of a Prestolite breakerless distributor with the cap off |
Goldcup101
We only ski recreationally outside a course so it's not worth my while spending as much as that for Stargazer. I only really want it work since it's there and I find it handy for accurate speed and rpm. If it all gets too difficult, I can just reinstall the 2nd Airguide or getone or both of them converted to GPS speed by NauticLogic.
DVskier
Senior Member Joined: September-04-2014 Location: Seneca SC Status: Offline Points: 449 |
You can get a new Stargazer from PP and be trouble free. Just make sure the power and ground are good. It's the way I'd go $1k, not much for the reliability and performance. Set it and let anybody drive for you that can keep a straight loss ne.
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4248 |
When I've contacted them in the past PP has had good customer service, might be worth giving them a call or email. It wouldn't surprise me if they offered to swap it out for reasonable money.
Mine is working perfectly, but I've noticed over the past month that I have to press on the up/down arrows harder to change the speed, worries me that they might be failing. |
Goldcup101
I was a bit doubtful too but an internet search suggested that these gauges reacted like this to moisture. Given that it often works ok-ish when ignition first goes on then starts fading as it warms up (engine running or not) it did seem credible that humidity could be to blame (humidity rising as the circuit board warmed up).
I've given it a switched relay directly from the battery and a dedicated earth so I think it should be ok in voltage terms but I'll double check it. Battery is new last year and the gauge reacts (and has always reacted) the same way when the engine is running so I'm pretty sure I can exclude the battery from the investigation. I get the beep no trouble, just looks like the actual LCD display as the information (when you can faintly read it) all seems good. Given that the coating has made no difference, I am inclined to agree with your scepticism! |
63 Skier
Do you have 14 volts feeding the PP? Mine fades with low voltage, my battery was getting tired and the gauge would fade and beep repeatedly with ignition on and not running, then would be fine once started. New battery and problem is gone.
Not sure I buy the idea that moisture causes an LCD screen to fade in and out. |
Goldcup101
Update: Speedo fixed!
Got myself one of these: Still need to install it, just short of time this week. Also got a vacuum/pressure gauge to check fuel pump pressure and set up the carb if it's not adjusted correctly out of the box. I noticed the Quick Fuel carb didn't come with a gasket but I've got a spare one for the 4160 and presume that'll work ok? Seems to fit. I've got a query about ignition though. The prestolite distributor doesn't seem to have points/condenser. Any idea what was standard fit in 1997 with the 285hp HO engine? assuming the points aren't hidden below a cover or something, is this breakerless ignition? The odd thing is that the engine does not have a ballast resistor and I replaced the coil last year with the standard one which says on it 'must be used with an external resistor'. Have I got the wrong coil here and, if so, what effect would it have? The Perfect pass gauge which fades in and out and is apparently due to humidity, is no better despite me having coated the circuit board in conformal coating to keep the printed circuit dry. So if anyone has one of these gauges for sale, I'd be pleased to hear about it! Thanks all! |
Goldcup101
Thanks Mark, As it happens, I do have a leak that I cannot find! Bilge pump copes fine but I replaced the leaky rudder packing and tightened the driveshaft gland this season so those two suspects are off the list.
One of the balance tubes doesn't have any tubing attached as the boat has PP fitted (not that it works mind) so there is every possibility that the other balance tube is the culprit! Will check at the end of the season; I can't face getting the back seat and tank out at the moment. I live in a ski resort so it very much freezes around here! Don't know what I'd do without this forum; thanks all! |
MACS81SN
Senior Member Joined: May-27-2009 Location: NW OH / S. MI Status: Offline Points: 109 |
Save yourself a possible headache down the road. Blow out the speedo line with the water in it before putting speedometer back in. If your in an area that freezes, water trapped in balance tube can freeze and crack the copper tube or blow the end off the tube. This can also create an impressive water leak when moving thru the water.
My 99 had one speedo that didn’t work we we bought it. Plus would accumulate 5-10 gallons of water an hour in bilge thru a leak I couldn’t find. On a hunch I blew some compressed air into the pitot tube and could hear air blowing on inside of transom. It’s a real PITA to fix as the tubes are mounted on transom behind the gas tank and tank has to come out to access.. The end was blown off my balance tube and just resoldered it to fix. |
1999 -SN - 502 Python 1981 - SN Owned 33 years - Sold 1968 - Mustang - Sold |
Goldcup101
Thanks Gary, that makes sense now. I'm slowly getting wiser. They say every day is a school day!
Anyone got any advice re the carb? And if I go the Quick Fuel route, does anyone know of a better deal than the standard $495? (This is presuming that the M600 is an OK replacement for the 4160 Holley 650 original? Price seems to jump if I want the QF M-650) And I'm sure I read somewhere that a new fuel feed connector of some sort is required? Potentially a new carb isn't required but I'm running short of ideas! A weird issue I forgot to mention before is a petrol smell when decellerating, seems worse in a left hand turn. No leaks around engine, carb, fuel pump. No obvious signs of fuel around fuel tank, from filler hose, fuel tank vent or fuel feed. Where the hell is it coming from???? |
Your on the right track. The balance tube acts like a shock absorber keeping the needle steady. No water is ever supposed to get that far up to the gauge,much like the upside down glass,the water only goes so far then the column of air compresses. The gauge measures the pressure of that column of air. The faster you go the greater the pressure,make a hole at the end of that column of air will let it out. What creates that pressure,in this case water,will then come through the entire system and leak out.
Goldcup101
Aha, thank you! I thought that the water pressure was converted to air pressure in the balance tube but obviously it must take water pressure all the way to the gauge.
I've got a spare AirGuide so I'll put that in and get to work on the knackered one. Cheers, you've just spared me from ordering a balance tube for no reason! Calum |
You are right on the temp gauge,go ahead and give that a try. The Airguide needs to come apart. Most likely the internal bellows has a crack in it because water at one time got in froze and cracked it. They can be soldered back up. It works like holding a glass upside down in the water, if it has a leak it will fill with water,if sealed the water stays out,the air inside is under pressure. That pressure is what is being measured.
relake
Senior Member Joined: May-18-2016 Location: IN Status: Offline Points: 126 |
You did a great job on the restoration, Calum!
Goldcup101
Hi all,
In the way that a house build is never truly finished, neither is the boat! Still have a few lingering issues from last year (and one or two new ones). I thought I'd post them here for the usual expert advice before I get stuck in! The Airguide speedo is literally filling up with water. The tube is blanked for the time being but I'm presuming the balance tube has gone. Does that sound right? Put in a relay for the PP but the display is still intermittent and even when operating, is faint and hard to read. A dedicated earth comes next but has anyone had a display go bad or the main module causing these issues with a display? The carb was rebuilt but not by an expert. I still can't get it right. It won't idle when cold despite a new electric choke (290 HO engine). When warm it idles nicely at 650rpm but will often stall when selecting idle or trying to accel past idle. Further, it bogs when accelerating out of the hole but picks up when the rpm increases/load decreases. New accel pump cam fitted, carb adjusted countless times, new plugs, leads, distributor checked. I'm on the verge of just ordering a freshly rebuilt 4160 or a Quick Fuel M-600 but have aniggling worry that it could be something else. Definitely seems like a fuelling issue to me though. Temp gauge quit recently. I gather that if I earth the sender wore to the block, the gauge should go to full defection. if it does then it';s the sender. If it doesn't then it's the gauge. Is this correct? Cheers guys! Calum |
fgroce
Senior Member Joined: July-05-2016 Location: Georgia Status: Offline Points: 350 |
Boat looks great, I know how much work it takes to get one all polished up.
Enjoy your boat. |
FGroce
88 Ski Nautique For 28 years Now 2002 Ski Nautique |
63 Skier
That boat looks fantastic! Really impressed with what you've done with it.
SNobsessed
Can't be the same boat as the 'before' pictures!
