'93 Sport Nautique - fuel issue |
Bri892001
Posted: June-04-2012 at 7:05pm |
Did you get any water inside?
Double check all of your wiring connections too. Maybe something with your ignition worked itself loose? Check the wires near your coil for tightness. |
gilbertaznautique
Newbie Joined: May-12-2012 Location: Gilbert, AZ Status: Offline Points: 13 |
I have a '93 Sport Nautique with carb.
I took it out two weeks ago, for the first time this season and it ran perfect. I took it out again today and everything ran fine until I hit a huge wake real hard. The boat died. It started back up, but from then on it sputtered. If I would punch it the boat would die. Finally I was able to fineses it to get it open, but it would still sputter. It would also sputter at idle. Any ideas? Somethig like a float got jolted knocked loose in the carb? |
