  New Posts New Posts RSS Feed - speed,rpm , 83 2001
speed,rpm , 83 2001
shierh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shierh Quote  Post ReplyReply Direct Link To This Post Topic: speed,rpm , 83 2001
    Posted: May-06-2016 at 4:15pm
Does anyone have record of engine rpm v speed with original 1:1 and 13x13 prop?
lets say 3000 rpm
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2016 at 4:40pm
It should be very close to 3o mph at 3000 rpm ...
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
skutsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2016 at 4:45pm
So Joe, does your 83 still pull close to the 1:1 at "normal" speed, I am guessing with your "slightly modified" (HA!) set up the answer is no,
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2016 at 4:55pm
Really once up on plane a 2001 tracks 1:1 all the way up to max Rpm. So like 25 mph to top speed should be 1:1 with rpm vs. speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2016 at 5:43pm
* with a stock sized prop
I believe joes larger prop allows him to under turn a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2016 at 5:49pm
it depends on the prop, nothing I use often runs as low as that, the biggest one that I run shows speed vs rpm in this video
Holeshot Video
