attn barr68 |
93/70 ccpb
Senior Member Joined: March-05-2006 Location: United States Status: Offline Points: 448 |
Posted: March-03-2007 at 4:26pm |
are you still looking for that jetson stern light for your 68 cuda?there is one on ebay under stern light,with the saucer like thing on top.
what you dont want to hear from jbear and bill.you cant get in the boat till you get your minute,and they throw you back in water!
barr68
Senior Member Joined: December-09-2005 Location: United States Status: Offline Points: 100 |
Thanks for the tip, I'll check it out. Jim B.
Barr68, I just wanted you to know that the Jetson light on E bay is not the removable type but rather the retractable that pushes down below the deck. With the gas tank in the way you need the removable. The Jetson light I got on Ebay a couple months ago was the retractable as well. I ended up converting it with a male and female connector in the base and the bottom of the pole. It wasn't that bad but did need the machining of a bracket and a bushing. The base already has holes in it for the bracket when it came as the removable type. I started with a 2 pole connector from West marine. Good luck getting it. Post your results as well as if you need any details / help on a conversion if you get it.
barr68
Thanks again, I was wondering if the retractable one would work. Jim B.
barr68
I got my Jetson stern light and my wing windows! Thanks everyone for your help!Jim B.
barr68, Did you get the stern light yet? I was just wondering if it will push down into the deck and clear the gas tank. I know I initially stated that it wouldn't but I'm going on knowledge of a friends 70 Barracuda.
65 'cuda
Our '65 has a retractable one and it misses the tank and the seat by an inch or so each.
barr68
Thanks for the input guys, I hav'nt received the part yet but, when I do I'll post an update. Thanks,Jim B.
barr68
Just to update the post, I received the jetson stern light and it matched up perfectly with the non retractable base that was on the boat(1968 Barracuda). it appears that this base was stock ,as the shape and style are identical to the jetson stern light.Chances are, Correct Craft installed what ever was on the shelf when the boat came down the line,which would explain why some were retractable and some not. Jim B.
