Belts |
85Nautique
Groupie Joined: April-30-2007 Location: United States Status: Offline Points: 69 |
Posted: May-25-2007 at 8:43am |
Stupid question- how much play should you have in the belt that spines the alternator. Mine has a ˝” of up and down movement is that to much and should I adjust the belt or replace it.
Should I be worried about the belt for this weekend? |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21131 |
I think it should be closer to 1/4" deflection. It only takes a minute to adjust.
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5772 |
Replace your belt if you see any signs of cracking or frayed edges.
As for tension, probably hard to put a measurement on it but I tighten mine fairly tight with a breaker bar to get some leverage. I don't go super tight, just enough so the belt doesn't slip at any rpm. An alternator under a heavy load (Killer stereo)may need to be tighter as it may slip after the batteries are drawn down from a float with the tunes on. Over tightening will affect bearing life in the alternator and raw water pump so don't over do it. I also spray my belts with a belt dressing when I change my oil. |
85Nautique
Thanks for the help
I try to make the ajustment before I take it out Monday Morning Bright and Early boat leaves the dock 630 I love the glassy water |
