High End Performance |
Post Reply | Page 123 4> |
Author | ||
Nautique2001
Grand Poobah Joined: June-14-2004 Location: Massachusetts Status: Offline Points: 2832 |
Posted: May-07-2007 at 4:10pm |
I'm trying to piece together 100's of older threads regarding high end engine performance. Could somebody just quickly give their input on this:
My rebuilt 351 engine has about 22 hours on it. The Holley carburetor is new, all electrical components are new. Hoses, filters, gas related stuff new. I think the only original parts are the starter and alternator. Fresh gas, 89 octane in tank too. At about 4,000 RPM's, I'm starting to run out of throttle fast. The tach reads about 4,250-4,300 TOPS, WOT with a new ACME 540. Listening to the engine and feeling what the boat is doing, my only conclusion is that I'm lacking sufficent fuel to the engine. I haven't checked the timing at high end yet. I've been reading stuff through out. What am I looking for the timing to be at 4,400 RPM's? The manual says no more than 30 degrees BTC. So does this mean 29 BTC is OK? Will adjusting the carburetor and timing cure lacking RPM's? The wacky thing is that when I have the throttle pinned, I'll be at about 3,800 RPM's then all of a sudden the engine adjusts it's RPM's to hit about 4,250. Everything else sounds and runs extremely healthy, except for the high 3,000, low 4,000 RPM band. I hate to repeat prior thread inquiries, but quick, short replies would really help. Thanks, Ken |
nuttyskier2002
Gold Member Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
You say your prop is new. So how new? I mean is there any history of your engine turning any higher than 4300 RPMs with this prop? Also, there's nothing wrong with a 4300 RPM WOT. What I'd be concerned with is the sudden gain from 3800 to 4250. This sounds like something is slipping - Either the prop or the transmission. But more likely the prop (if it's not cupped). What speed are you reaching?
To answer the question about timing, max timing advance should be reached by 3000 RPM. With the stock distributor, base timing will be 10 deg BTDC (screw down cap) and end up somewhere around 28 - 32 deg BTDC @ 3000 RPM. Some guys here have posted that they have achieved better performance by re-curving their timing advance to reach 35 - 37 deg @ 3000 RPM. I'd be very careful in trying this. Good luck and please post your results. Brian |
Former boats: 88 Ski Centurion Tru Trac II 59 Chris Craft Capri (woody) |
Munday
Gold Member Joined: August-17-2004 Location: United States Status: Offline Points: 538 |
It could be stuck advanxe or just plain wrong advance in distributer.or even sticky secondaries.
Munday |
79nautique
Ken
you should see max advance by 2500 and no latter than 3000 rpm at around 30-35 the more the better as long as it doesn't ping on the top end. I would focus on the fuel pump makes sure you have a constant 5 lbs of pressure and also check the carb, it will need tweeked regardless if it was just re-built or new out of the box, it is a 600 cfm model correct?. To me it sounds like you have an issue with the secondary's on the carb or maybe a 2.5 power valve in it. might even be too small of jets on the secondary side as well. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21135 |
The secondaries on a stock 4160 wont have jets, only the metering plate. Nutty, I dont think 4300 RPM sounds right. A stock 351w in a 2001 should be turning a 540 closer to 4600 RPM. From what I remember, Ken was turning his previous 4-blade 4100-4200 RPM, so the problem was there before the swap. |
79nautique
tim don't believe ken stated what carb he bought to start with so was listing all possible options to look at encase he does have a model that has secondary jets.
Nautique2001
Thanks for the input. I'm not looking to push the engine beyond the factory specs. I'd like to be able to reach the maximum performance specs of 4,400 RPM.
The ACME is brand new and recently tuned. I have a Holley carburetor, which has 22 hours on it. It has "High Performance" stamped on the side of it, I'm not sure of the model number. Does an engine go out of original adjustment after the break in period? I haven't verified the timing since it was installed in late 2005. Tim's exactly right, my four blade OJ wasn't spinning up to the max RPM range. I actually had OJ make adjustments to give me more RPMs, as I was spinning 3,800 max when I got it. Since the new "rebuilt" was installed, I've never reached maximum RPM, 4,400. It could be an adjustment that needs to make all the difference. Ken |
79nautique
the carb number would help more than knowing it say's high performance on the side. And yes the timing needs re-checked the timing chain will stretch and you need to check what the advance is at 2500 rpm as well. You will also need to dial in the carb as well it's not a bolt on without any adjustment needed type part and it goes way beyond setting the idle mixture screws, choke stat, and idle settings.
Nautique2001
Tim,
I just shot an e-mail off to you and Brad about using my boat tonight. I want to grab my Dad's timing light and see what we have for settings. I can be the boat of choice for this evenings pull. Ken |
Nautique2001
Thanks, Chris. My boat wasn't lake tested after Correct Craft installed the new motor. I'm sure I have some adjustments that are necessary at this point in time. I've seen how bad timing throws off the entire program with performance. I'm actually going to go get my boat during my lunch break and grab the numbers off the carb. I'll let you know.
Thanks |
Hollywood
Ken I'm going through pretty much exactly what you are with our '88.
I couldn't get more than 4300 rpm with a 12" pitched prop. The stock 13" pitch brought me back down to 4150 rpm at WOT. I wouldn't be concerned with what the tach is telling me except that's at a GPS verified 38 mph. I've checked the throttle cable and looks like it's properly adjusted. Timing chain feels tight. I will keep you posted although it sounds like you're attacking your issues sooner than I will be. Boat will probably hit the water next weekend for fuel pressure and timing checks. Going down to TX to take a few sets behind Feelgood's BFN this weekend. Hopefully I can learn a few things from this thread when I get back. I have an unknown EI conversion that uses a ballast resistor and an oil filled coil. Magicman's tuned 4160 is ready to bolt on for testing as well. Just put in fresh plugs and fuel filter. |
Nautique2001
Hollywood,
Pretty mind boggling issue. The engine runs like a top until you hit the high 3,000 RPM band. I'm sure you feel the loss of throttle response like I do from 4,000 to about 4,300. I never thought to check the position on the throttle cable. I'm pretty positive the timing and carburetor adjustments aren't jiving. I think we'll start by advancing the timing a couple of degrees and turning the two adjustment screws a quarter towards the open position. I don't think the prop has anything to do with the lack of RPM's. I'll post something tomorrow. Ken |
Ken, I saw your email. If you get a chance, grab the List number off the choke horn. It should be somewhere around here:
Im assuming its a stock 351w replacement either from SkiDIM or Correct Craft, so it should be a 600 CFM 4160. The Holley tech line will be able to ID it for sure based on the List #. Its quick and easy to dial in the timing. We can verify youre getting full advance- it sounds like the stock dist should be getting 20-24 degrees on top of the base (can anyone verify that number?). Based on what youre seeing though, Im with Chris and think there may be an issue with the secondaries. Beyond that, I couldnt tell you what to adjust. |
Nautique2001
Tim,
I'm going to Natick to go pick up my boat and timing light. I'll get you those numbers. What about the accelerator linkage piece that opens the secondaries? Can that be adjusted to let more fuel in? Tim, we also need to check the throttle linkage to ensure I'm getting max throttle. This is a 22 hour carburetor, so I assume it's not wear and tear. Ken |
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3336 |
No. That closes the secondaries
always a valid check |
River Rat to Mole |
bkhallpass
Sounds like Ken and Hollywood have lemons. Tell you what, I'll give you $2500 a piece for them, and I'll even get them back to CA at my expense. You can use the money for a down payment on a shiny new boat with all the power you need. Just trying to help a brother out. BKH
Livin' the Dream
79nautique
wouldn't do that at all you do not have a rough idle issue and adjusting the screw will not effect off idle performance like your having. Check the cable adjustment first to verify WOT at the carb, then move to the timing set it at 8-10 inital and then see what the timing is at 2500 rpm should be around 30 degrees after that you need to focus on fuel delivery and when and if the secondaries are opening. Kevin, I'll be in the countryside area? electromotive diesel plant next week and I might be able to stop by and help you out if you want. |
backfoot100
Ken, these are the idle mixture screws. Adjusting those won't do a thing for the WOT issues that you're having. One thing to check is to take a paper clip and put it on the secondaries linkage. Take a run at WOT and as the secondaries open up, the paper clip will slide along the linkage and stay there when you throttle down. You can manually open the secondaries (with the engine off obviously) then and verify that they are opening all the way. Also pull your plugs and check them to make sure that you're not running too lean or rich. You again take a run at WOT for a few seconds and just turn off the engine before you throttle back. That will ensure that you get a good indicator of the plugs at WOT and not idle or mid-range. |
backfoot100
Hollywood
Thanks Chris, I would take you up on that offer except I will be out of town all of next week, as well as most of the week following. I will be buttoning up the boat tomorrow night to get ready to run which won't be until the 19th. This is an embarassingly late start for us, although I have been skiing several times this year already. |
Nautique2001
I just took a couple of pics. Not sure if this helps determine which model it is:
Hollywood
Pull off the arrestor and get the damn numbers off the air horn already.
Nautique2001
Brian, I'll trade you straight up! |
Nautique2001
Be right back, I'll go grab a wrench... |
MaddMarxx
Try not to drop the nut down the carburetor...
Nautique2001
Ooops. Kidding... SAE J1223 75009-3 1195 |
Hollywood
MM, you don't know the difference betwen a nut and a bolt? I would expect that from blondie but not you.
I also forgot to mention how much I like the looks of that annodized arrester. Classy.
Nautique2001
You like the gold look? Gives it a little pop.
So is the 4160 a decent carburetor? I just need the thing to spew as much fuel as possible at WOT. What's the trick with this little monkey? We'll be on the lake in T=90 minutes.... Ken |
Holley tech says its a marine 4160 with vaccuum secondaries, 600cfm (just like we thought). |
Nautique2001
Tim, I hope you're taking notes here. Hopefully it's something simple.
Maybe this woman is hidding in our bows, Hollywood. |
