Key stuck in prop |
Author | |||
GTH852001
Newbie Joined: June-01-2020 Location: Michigan Status: Offline Points: 12 |
Posted: May-16-2021 at 9:23pm |
Hi All,
I read through the prop pages and didn't see any mention of the issue I am having on my 1985/2001. I am removing the prop for strut bearing replacement and possible prop replacement. The prop is loose but the key is stuck in the prop so the prop will not come off. I have tapped on the key with a narrow punch but it is not moving. Also soaked in PB blaster no help yet. The prop hasn't been off for 20 plus years, yes that means my strut bearings have not been replaced in 20 plus years. Any ideas? Thanks! |
SNobsessed
Maybe remove the rudder, remove the transmission coupler flange, then pull the whole shaft out.
Then you can work on it without hitting your head on the rudder, etc.
Greg,
What type of prop puller are you using? Some of the C clamp styles will stretch too much. Have you tried any heat?
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10667 |
I think he's using a puller that works since the prop is loose already.
Possibly not using a puller since if he was, the puller should pull the prop off a stuck key.
I'm a little slower than normal this morning Pete................the key is stuck in the prop so why don't you explain how the puller will get the key out of the prop
"the prop will not come off" "the prop hasn't been off in 20 years'
What about those other words you quoted............"the prop is loose"
it's loose and with the key stuck in the prop, he can't slide the prop off of the shaft
My first thought was time to start hitting the gym when I saw this last night. Second thought was to pull it off with the puller- stack a 1/4 “ deep socket between the puller and shaft if needed and keep going. Rather than go through all the work of removing and reinstalling the coupler and rudder cut the prop off 😉
Yes, if he's run out of thread on the puller, then I too would back it off and add spacers.
Well Pete, you can read it however you want to but obviously you've never tried to get a prop off that's been loosened with the puller and the key is stuck in the prop like he stated
It can't be done without destroying/damaging something because that key hits the threads when you're trying to get the prop the rest of the way off the shaft.
The key has to be out of the prop if you want to get it off without damaging anything Give it a try. |
I don’t see why this is so hard to understand, ha. The solution, unfortunately, is a PITA.
The last time this happened to me, I took a grinder to the shaft threads in order to give the prop (with stick key) a way off. Not pretty, but effective- and I have used the shaft subsequently (just clean up the threads). Getting the key out of the prop even once it’s off the shaft is still a big problem- but if the prop is old enough to have this happen to it, it’s likely a mantle ornament anyways. |
I don't understand the issue ether. The stuck key jobs I've done a couple did did get stuck on the threads but with the brass keys, the key takes more damage than the threads. Then a little tune up of the threads with one of these and you're back to good.
0% chance of getting my most recent stuck key past the threads without the clearance job… the location within the taper where the key is stuck probably is a factor in whether it’ll sneak past the threads or not.
So i guess now you finally understand the title and his problem
I never had any doubts and the reason my first question was what type of puller he was using.
Umm yeah .....Whatever you say
GTH852001
This thought did pass through my mind, since I probably will need the shaft out to get the strut bearings out. Will the shaft come out with the prop still on it if the boat is on the trailer? Looks like it might not clear the trailer skid plate. Sorry no picture but I hope you know what I mean.
Thanks, Greg
GTH852001
TRBenj,
That would do it, not sure I could make such a cut under the boat. I may try to pull the whole thing out as I wanted to change strut bearings too. Thanks, Greg
GTH852001
8122pbrainard,
I am using a three bolt (all thread) style puller. U shape (three threaded holes) behind the prop, with U over shaft and a round circle with three through holes on end of shaft/nut. I have the prop loose, it slides about 3/4" of an inch from operating position towards the back of the boat until the key hits the shaft threads. I have already buggered up the thread nearest the keyway from running the key into the threads. I guess I could pull it over the threads and clean up the threads later. Thanks, Greg |
Greg,
If you can't move the key to avoid the threads then I feel you keep going with the 3 jaw puller is an option. The key should be brass so it will get damaged more than the threads on the shaft. Keep going and see what happens. The prop nut is there to seat the prop on the taper and not to hold it on so I don't feel that with some threads missing you will have a problem. Just make sure you lap the new or the old prop back onto the shaft.
GTH852001
All,
Thank you for all the suggestions! As I was considering replacing the prop too, any suggestions on where to find the best replacement prop prices online? Wakemakers? My Inboard Marine? Are the ACME 540 or 542 that much different? Thanks, Greg |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2858 |
Acme seems to be the go-to manufacturer for props. Delta Propellers is (or used to be) a site sponsor, and is a good source. Also forum member Tim Benjamin (TRBenj) is an Acme dealer. Give them a call for prop advice.
Greg,
Just as JQ mentioned, the Acme props sure seem to be the go to but alot depends on what you have now. If the present prop is a older cast/hand worked then you will definatly see a major difference. If you go Acme, they too recommend lapping their props to the shaft.
GTH
Post pictures of the shaft threads when you're done
I guess GTH is having a real hard time getting the prop off or maybe he just "ain't ever gonna update this thread"
I ran into one of these dismantling a boat a couple of days ago and had a shaft that looked at lot like TRB's picture when I was done
scootdogydog
Senior Member Joined: November-03-2013 Location: Central MA Status: Offline Points: 404 |
This is something that I encountered last year. The key split in half when I hit it out. |
The key sheared because somone didn't install the prop correctly. I'd say it wasn't lapped to the shaft so all the torque was through the key.
