Foam Density Question |
dip
Senior Member Joined: August-29-2009 Location: Eastern PA Status: Offline Points: 392 |
Posted: March-15-2021 at 5:08pm |
I am going to repair some wet foam. What density is better to use? It is available in 2lb or 6lb from Jamestown Distributors.
Thanks
The 2lb. is what was used. The primary purpose is flotation and the reason for the lighter foam.
dip
Thanks Pete.
67 ski nat
Platinum Member Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1184 |
Read instructions of your 2lb closed cell
The foam I used was also dependent on temperature. Warmer is best(80) little more expansion for more flotation Cold weather (50) probably tighter less floatation Disclaimer: poster shall be held harmless for crapping info |
ArtCozier
More important than the density of the foam is that it be closed cell foam. Meaning that there is no interconnection between the cells of the foam. Open cell foam is like a sponge; water can travel from one cell to the next. Open cell is almost gone off the market, but make sure.
"Art"
dip
Thanks for the replies. Definitely waiting until it warms up a bit more to do the work, and no open cell sponges for me! Looking forward to getting started on it.
