Prop size |
DasBoot67
Groupie Joined: July-13-2014 Location: Danville nh Status: Offline Points: 74 |
Posted: January-02-2021 at 3:53pm |
I have a 12 by 12 prop what else can I use I have a 67 mustang 289
Andrew, The 12 x 12 sounds like a good fit for the 67. What's your WOT RPM's? That will give us more to go on.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10667 |
You should probably update the thread in the link below with things like prop to strut distance and prop to hull clearance when you got things all back together if you're wondering if a bigger prop will fit and have decent clearance to the hull |
GHTILL
Senior Member Joined: July-29-2018 Location: Aledo Status: Offline Points: 172 |
Can't resist this opportunity.....
SIZE MATTERS |
TWSS
