  New Posts New Posts RSS Feed - 1978 Fish Nautique
1978 Fish Nautique
leetudor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2020 at 7:39pm
How does this prop nut hot garbage work out?  I bet this is not factory setup either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2020 at 7:51pm
Lee,
It looks like the PO used a prop with it's bore bigger than the shaft? Is the prop at least seated on the shaft taper or loose? How close is the prop hub to the strut?
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2020 at 8:06pm
Lee,
I am going to pull the prop tomorrow and see what is up.  When I first looked I just noticed how close it was to the strut and not all of the spacers.  The prop is maybe a sheet of paper from the strut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2020 at 10:51am
Well in this politically correct world, this thing was rigged.  Prop must be 1 1/4" hub, as a 1 1/8" prop I had sitting around fits the shaft correctly.  Someone had to make a special keyway to match the shaft and the prop.  They used Teflon tape to take up some of the slack.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2020 at 11:02am
Ugh.
Amazing the effort people make to do things wrong and be proud of it afterward
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2020 at 11:21am
WOW, that's not something you see everyday!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2020 at 6:36pm
It's amazing it stayed on at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrarunner Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2020 at 9:55pm
I’ll say. Had to been a good vibration. All held together by that cotter pin. Loose a prop at sea and someone stocked the wrong size spare, ok, I get that. But on purpose for daily use??? That’s some thinking there.
In all fairness, it does case me to pause and think a bit at what I did to keep my old cars running as a kid with little or no money;-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2020 at 10:03pm
So I installed the standoff transmission mounted shift cable bracket and routed the cable the new way.  Well have to order a new cable 8 feet shorter now.  The way things are going, I am going to install the cable before I change the throw on the handle side as it could be wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote leetudor Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2020 at 8:22am
Hope to have it running this week!
