Pylon Ring and Finger replacement |
WC78
Newbie Joined: September-06-2019 Location: Illinois Status: Offline Points: 17 |
Posted: September-27-2020 at 10:36am |
Glad it worked out.
Justin, Mobile devices are a problem and it's almost impossibile to use them for picture uploads. Email them to a PC or a laptop and here's the procedure: |
ski4life78
Newbie Joined: August-17-2014 Location: Lake Como, WI Status: Offline Points: 10 |
Yes I did. It worked out great. I took a few pictures but can’t figure out how to upload off my phone to here.
WC78
Did you get the new pylon top part installed?
ski4life78
I have had the ring and finger out for years. Wasn’t fun at that time though but got it out without ruining any of it so it can always be installed again. Been using a extended Pylon but now I can slalom ski without having to put it up.
I guess you got the old one out with no issues?
Sticky thread in general topic section:
It doesn't work well on a mobile device.
ski4life78
I received it yesterday. Looks great. How do I post pictures on here?
ski4life78
It should be arriving tomorrow and I will be putting it in this weekend. I will post pictures when it’s all done. Can’t wait
WC78
Did you get and install the new pylon top part?
WC78
I just reused the original ones. They were in good shape, even though they were 40 years old. I think they're stainless. I'm pretty sure they're 1/4", going by memory.
ski4life78
Thank you. That looks awesome. Can’t wait to get mine. By chance to you remember what size roll pins you used?
WC78
Another installed photo:
wsavini
Senior Member Joined: September-06-2012 Location: Taunton, Ma. Status: Offline Points: 282 |
Peter, That is a great idea! Ty
Make it a big one they can be stubborn. I would use a grade 8 bolt so you can crank on it without it breaking.
wsavini
The guy cut it even with the top of the pylon. I will need to drill it and maybe put a bolt in it to grab onto.
Drive out the 2 roll pins and (since yours is already destroyed) a large pipe wrench, twist and lift.
It's a smooth shank that's in the pylon no threads, they get corroded and can be tough to get out. When I pulled my '85's I used a little heat on the pylon to draw in some penetrating spray let it sit over night. The next day more heat and spray and it wiggled right out.
ski4life78
On my ‘78 it is just held in by two roll pins. You have to tap them out and then I sprayed the ring and finger with pb blaster. I then used a piece of pipe through the ring and started twisting it carefully back at forth until it became loose and I could pull it out.
wsavini
How does the ring come out? Is it threaded in? I bought a 83 BFN and the meathead I got it from cut the ring off with a sawzall so he could put a extension on. I’d like to get the rest out so I can replace it.
ski4life78
Yes I totally agree. Can’t wait to get it.
WC78
That's in line with what I paid. Well worth it in my opinion for a quality, custom made to order machined part.
ski4life78
Talked with Shad today. Said he believes the cost is $125
That's not a thing-a-ma-bob, it's a Do-hickey!!! A thing-a-ma-bob is more expensive, like a what-cha-ma-call-it.
What is the cost for one of those thing-a-ma-bobs?
ski4life78
I got in touch with Shad and he is going to make me one next week. Thank you for all your help.
WC78
Here's the installed:
WC78
WC78
Here's a couple photos of the part (loose and installed). Let me know if you have any questions. Good luck.
WC78
Hi,
I don't know if Shad is still there, but very possibly. If not, someone else may be able to help. They had the print of this part on file. Shad was super helpful. I was happy with how it all worked out. Fly high pole fits perfectly over the new pylon top. I have the old ring if I ever want to put it back on. Shad's contact info is: Shad Zulch AW Manufacturing & Repair 1300 Wohlert St. Angola, IN 46703 p.260-665-3061 f.260-665-3849 stzulch@angolawire.com |
