Poor idle |
Author | |||
Mpost
Senior Member Joined: July-05-2018 Location: Monticello, MN Status: Offline Points: 328 |
Posted: June-20-2019 at 8:30pm |
May I ask if you are running any additives in the gas? Are you running oxygenated gas?
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10718 |
That looks very familiar Just tell yourself the third time is the charm |
bfootr
Senior Member Joined: March-04-2019 Location: Benson, NC Status: Offline Points: 138 |
Keno - Looks like you were correct. As requested, here's a pic of the defective diaphragm. Mind you, this pump has only 3 trips out on it and is the 3rd (and final) Carter pump I've installed in since Dec). Fortunately (I guess), I only paid for the first one. We'll see how long this one lasts although my expectations are low. |
bfootr
Thanks!!! I ordered it. Much appreciated. |
Here's a bit of a guideline from another thread
This was to access the damper plate so in addition to what's listed here, you remove the damper plate and the flywheel to get at the rear main seal
Well it's later today and here's a number for a Holley renew kit that will have both styles of needle and seat assemblies and all the other parts that you'll need. The number is 37-119. Don't worry that it doesn't say "marine", nothing marine about any of the rebuild kit parts |
Don't listen to Pete Your engine being an 89 has a one piece rear main seal and it can be done in the boat without removing the oil pan. Also being an 89 it's normal rotation and a regular automotive one piece rear main seal will work just fine You'll still have to jack up the back of the engine enough to remove the transmission, then the bellhousing and the flywheel. Then you'll be staring right at the rear main seal. It's only a mild PITA |
bfootr
Yeah, I changed the trans oil to the recommended red fluid. |
Pulling the engine and removing the oil pan. Some have they have done it with the engine in the boat by raising the aft end of the engine so the pan can be dropped. In my mind, that would be a real PITA. |
bfootr
I think so too. What's involved in replacing the rear main seal? |
No, it will have the wrong needle and seat assemblies. I can come up with a number that should work for you later today. As far as the oil, the good news is that your transmission isn't leaking assuming it has red transmission fluid in it. An 89 with the PCM 1.23 to 1 transmission had brown 20 weight oil originally and maybe that's what's still in it. That means there must be bad news though.............the rear main seal on the engine is probably leaking if it's not the transmission leaking. |
bfootr
So as long as I reference the List # 50463, I should be able to get the right rebuild kit? |
bfootr
It's definitely brown engine oil. |
I asked about the carburetor picture earlier because the original Holley 50463 would have had internally adjustable floats and uses different needle and seat assemblies than the externally adjustable bowls that it seems like somebody added sometime over the years. The Holley rebuild kit referenced earlier will have the wrong needle and seat assemblies , you can find kits that are more "universal" with both styles of needle and seat assemblies. |
William, There isn't a "seal" between the bell housing and engine. Oil at that point is ether engine oil or trans fluid. What color is the oil? |
bfootr
Will do and will post back findings and a pic. Thanks! |
Assuming they don't want the bad one back, why don't you remove the housing and see what the diaphragm looks like.
A picture would be good. The bad ones seem to have a shiny diaphragm ( a neoprene coating over fabric) that peels and cracks easily. Glad they're sending a new one to ya' |
bfootr
Here's a pic of the carb. To set the float levels, I'm removing the float level screws (circled in red) and adjusting the float levels by the nuts and set screws (circled in yellow). until the fuel trickles out of the level ports. |
bfootr
HA! Surplus Fuel Pump Emporium...from Amazon. I called Carter's technical assistance line today and it appears some earlier versions of this pump were defective. They are overnighting to me a "new and improved" version (new stock?). Going to try it one more time and if it happens again, will definitely go with the AC version. As for the vibration issue, seems to be much better now. I checked the shaft coupler/trans flange alignment 3 times to ensure it was w/i the .003 spec. Adjusted the carb which resulted in the engine running smoother (outside of the flooding caused by the fuel pump issues) and this has fixed most of the vibration. I think any vibration now is normal as part of the Harmonic balancer as mentioned. I am getting some whining noise at idle at first start-up just in front of the trans but it's not coming from the trans. Maybe the damper plate? Seems to go away when warmed up. Also, leaking a small amount of oil below this area towards the rear of the engine. I noticed that one bolt connecting the bell housing appears to be stripped which may be causing the seal to leak. Will dig a little deeper into this. Slowly getting these issues fixed on this 30 year old girl! Up to the final run last night and the fuel pump issue, she ran like a champ! |
Well that sounds like 2 strikes against the Carter M60389. It's pretty hard to install one wrong so it's probably not you causing the problem. As mentioned in your previous thread, there have been diaphragm issues
Where are you buying these pumps, Joe's surplus fuel pump emporium ? You could try for 3 strikes or you could try a Sierra 18-7267 fuel pump. It's a copy of the AC dual diaphragm pump for a 351W and nobody seems to be grumbling about them. The suction and discharge are in slightly different locations. Suction side is easy, but if you have metal between the pump and the carburetor, some bending or a new line would be needed. No guarantees, but I'd go this route before electric. Plenty of mechanical pumps running just fine out there. link AirTex also sells a 60389 which may or may not come from the same place the Carter's do BTW how's the vibration issue from your vibration thread? |
Seems so
My 2nd last fuel pump puked two check valves in the same moment and stopped me dead Its replacement had fuel out the vent just prior to my engine work last fall. Form out data points, they don't make them like they used to. Mine were the brandless, two from skidim, one from summit. mIss the original carter, lasted 30+ seasons Appears Fuel Pump is the new weak link on these engines |
bfootr
Update - After adjusting the float levels, I took it out for another test drive yesterday and it ran perfectly at all speeds including idle UNTIL... after running it hard on our final run, it started to act like it was flooding and was hard to keep idling. Again, had to advance the throttle all the way to get it started. Raised the engine cover and once again noticed fuel moving in the clear sight tube from the mechanical fuel pump. This is the second new fuel pump that I’ve put on since Dec - This one only has only two trips on it since installation. Is this once again another bad diaphragm in the pump? If so, thoughts on what would cause another one to go out? It’s a Carter M60389. Thanks in advance for the help!
Maybe a picture of this carburetor and what you're doing to adjust the floats would be good
This would be the Holley rebuild kit in the link below 703-29 assuming the carb is original (no bowl style changes etc) Whether you think you need it right now or not, it would be good to have on hand. Hope you were better at "adjusting" the second time around. link It's a Holley 4160 you have. The books cover a whole variety of Holley carburetors, but they all have sections on basic functioning, theory of operation etc that will give you a good understanding of your Holley carburetor. |
bfootr
Is the carb list # 50463
0909 the same as Holley 4150 or 4160? Want to ensure that I’m buying the right book. |
bfootr
The list # is 50463 0909 |
bfootr
Well, guess I didn’t set the float levels exactly correct as I checked them again today and the back float level was pouring out fuel from the level drain. I reset the level again and the issue of the dripping fuel into the venturi’s ceased and engine started idling as it should. Will water test it again tomorrow. Thanks for all the help.
bfootr
Choke seems to be working fine. |
Also buy yourself one of the many Holley carb books that are out there
Check the link for some examples You'll learn a lot from any of them. Plenty of pictures and good explanations and exploded views link |
Since you've already checked/set float levels, you should be taking out the needle and seat assemblies and cleaning them or replacing them with new ones because they're either leaking due to junk in the seating area or they're worn out.. If you post the list number of the carburetor, it will make it easier to find the right carburetor kit for it. It's stamped on the air horn of the carburetor. An example is shown in the picture. And............after you clean /replace the needle and seat assemblies you need to be sure you have a good filter in the line somewhere or you'll be having the same issue all over again if you have junk in the fuel system. |
