Stringers |
Post Reply | Page <1 45678 10> |
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Online Points: 13512 |
Breadth of info here for a thread titled “Stringers”
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Online Points: 3604 |
One more congratulations on the fine seat work. Very classy look.
Nautiquehunter
Thanks Guys I can easily fabricate the seat bases now.
I'm sure you will come up with something. Originally Correct Craft used an aluminum extrusion that allowed a bolt to come up from the bottom and yet the bolt head was not poking into the pan. Rather than staking the bolt they used a nut much like a nylon insert lock nut and from the top placed that nut to hold the bolt tight. Then the seat frame was drilled so that it piloted on top of that lock nut with the rest of the bolt length protruding through the seat frame so the chrome hold down was easy to attach- a simple and easy to use solution requiring no tools to remove a seat.
67 ski nat
Platinum Member Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1184 |
Hey you should open a Upolstry shop nautiquehunter. That’s money , great shape and detail
Duane in Indy
Looks to me like the best way to do it would be to make the bottom plate with tapped holes in it to match the pattern of the top part. Then use S/S Heli coils or inserts. Then affix the bottom plate to the floor or pan. The top plate could then be secured with knobs with a stud coming out of them. With this setup you would not have these studs sticking up from the floor when the seat is removed. Stepping on them would not be fun.
1978 Mustang (modified) |
Vtox39
Newbie Joined: April-04-2020 Location: Sml Status: Offline Points: 14 |
Mike and Gail your project looks awesome! You guys are so talented I’m so glad you gave me a big helping hand on my first boat fix up. You guys made it fun and enjoyable. What a stringer job and I can’t imagine the hull work on the bottom!
Nautiquehunter
Work has finally started again on the 67 . Thanks to all the time off between wooflew and holidays it has really started to move forward. Trying to get it done before the SJRR in march. If progress continues I just might make it.
Nautiquehunter
When I got the boat it came with a ladder on the back not only was it bent but it looked useless since it didn't go deeper than the bottom of the hull. I am thinking about building a wood swim platform on the rear . what do you think the pros and cons would be .
DVskier
The benefit of a swim platform is tremendous for water sports. I couldn’t do without mine as I ski 3-4 days per week from March to November. Some will say keep it original. I say keep it usable. I had a friend with an old Hydro Dyne outboard. I had to it my slalom ski on in the boat and flip over the gunwale to enter the lake. Unnecessary.
Morfoot
Tweety is looking great Mike!!! You know me... I say keep it original but I also know with Kermit of what a PITA it is to get in the boat after a ski or a swim. As much as I hate platforms on the back of 60's boats I say do it. I know you and Gail and on days that will allow you to use the boat without competing with the 40 ft yacht wakes you will want easy access to get back in the boat.
Back in the days when men were men and we barefooted with cutoffs and a ski belt. the weak used over the gunnel ladders.
Pete, pictures or it never happened. Whats that thing on the back of your Tique? The Mustang is looking great and will look fine with a platform and it will be so much more enjoyable to spend a day on the lake with.
Bruce, The ladder is simply a option. BTW, my Tique isn't a 60's CC.
jimsport93
The boat is looking great Mike and Gail !
Nautiquehunter
At 65 and moderately overweight I will need something to get back in . The ladder that was mounted on the back I think was original one of the legs is bent so it will have to be replaced but it still only goes to the bottom of the transum .I don't see how that will be much help . I think it will take away from the lines of the boat even more than the platform. I just spent 2 years grinding out and filling 10,000 cracks in the gelcoat . The last thing I want to do is to hang a ladder off the side and watch it scratch. If anybody has a mid 60's Mustang with a platform can you measure the location of the brackets from the bottom of the hull and distance to the sides . This boat has never seen water since I got it . I have no idea where the water line was or will be now.
jimsport93
I vote for the platform
Morfoot
Pete, I've got one of those hook ladders for the Mustang and do use it from time to time. Even though it folds up it still takes up precious space in a confined boat to start with. My wife will use it but doesn't like it at all. She'll swim to a raffted up boat, use their platform to get back in the boat before she uses the ladder. I already gave Mike the 3rd degree and riot act about using a 80's Supra pylon in this boat instead of the OEM ring and finger which he caved after I reconditioned the old for him so I'll throw him a bone and agree to the platform.
Nautiquehunter
The work continues big push taking advantage of some slow time at work. Working on the fuel tank install very tight but I think it will fit . Wife and I finished up the side panels and gunnel wraps. If I can stick with it I should have the drive train back in by the weekend. I pulled the aluminum rub rails out of the barn only to find I don't have all the pieces .Looks like the rear corners are missing. I will try to find pics of what its supposed to look like.
Holy smokes Mike I think that's George Banana Blair's first Cypress Gardens Banana Boat! Great job you and Gail are doing
2001SAN
Senior Member Joined: June-26-2012 Location: Ireland Status: Offline Points: 242 |
Agreed, that is looking awesome. You must be reeling in job satisfaction!
D
A little knowledge is a dangerous thing...
2001 Super Air Nautique 1989 Fairline Corniche 31 www.bannrivercruises.co.uk |
Outstanding! in awe of the talent and execution
Mike,
Great job on the upholstery. You should go into the business! (or your wife)
Morfoot
Gail does Fantastic work! She did the Drivers seat and observer seat bottom in Miss Scarlett and recently made a custom cover with side skirts for her too using Sunbrella canvas. She's a woman of many talents... She sold us the lake home we're in too. Looking good Mike. Holla' if you need an extra hand this weekend.
NCH20SKIER
Very nice indeed
'88 BFN |
Nautiquehunter
Thanks guys its not a museum piece there are plenty of flaws if you look close enough . I wish I had started with something in better shape to start with . It's been 2 years and endless hours . When I think back to when I first got it my brother in law said you gotta be nuts to fix that thing . Then Morfoot came over and went crazy over the fact I had a Mustang. He has been very encouraging and supportive keeping me on track . I got the boat for free I am still debating whether I paid too much. The name of the boat is Tweety in line with Tims Kermit.
samudj01
Gold Member Joined: March-10-2009 Location: NC Status: Offline Points: 947 |
Very nice. Looking forward to more updates!
pjsmoreno
Senior Member Joined: April-25-2016 Location: Liberty, Mo Status: Offline Points: 166 |
That will be an eye catcher once it's on the water!!
What dedication and a fine job!
Nautiquehunter
We are working on the interior . I set the seats engine cover and pylon in boy is this boat getting SMALL . I think it was made for kids or munchkins . The rear seat is next then the drive train . I will post pics later.
