Stringers |
Post Reply | Page <12345 10> |
No, there isn't as long as the extra thickness is to towards the hull sides leaving the same distance between the mains for the engine. |
Nautiquehunter
Thanks Pete you have been very helpful.
Mike, Again sorry to hear about your experiences you mentioned. The SOP for blocking isles during store open hours is only to retrieve or down stock items that a customer is waiting for. There are times when say a contractor calls in an order say for drywall or lumber and he's on his way to pick it up that we will close down isles. Safety is a major concern at the HD and strictly enforced especially after Menards killed a customer. He was in a isle behind where a fork lift was operating and the fork lift pushed a pallet of tile down the opposite isle. It's the reason we have to block the two isles. The one where stocking is done with lift equipment and the isle behind. |
emccallum
read the whole thread hoping for some great stringer pictures.............
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10704 |
And now you know a lot about veterans discounts among other things |
"The journey of a thousand miles begins with one step." |
Nautiquehunter
Well I finally tracked down a lumber yard that can order Doug fur they stock southern yellow pine . They couldn't give prices on the DF until Monday but they warned it wont be cheap. I am going to go there Monday and look at the pine . They said it is grade A so if it doesn't have any large knots I may go with it. Realistically if the boat only lasts 20 years and not 50 I think that will be fine. I am working on getting pics from my phone to the forum I intend to fully document the build for all to see and advise on procedure.
Morfoot
Sounds like you've been a busy boy Mikey.... When time allows Heather and I will have to make a trip up there and see whatcha got. I know a guy so I might even be able to bring a stringer rebuild care package with me.
Nautiquehunter
Not much to look at now just cleaned and dry. I have to set the 351 in it and see if any mods have to be done to the existing stringer set up to accept the 351 . Should be fine small block ford to small block ford. From there it will move into the basement where its climate controlled . That work thing keeps getting in the way I worked my A$$ off in November so I am hoping to take some serious time off now till next year.
Nautiquehunter
I heard the Atlanta boat show is going to be much smaller and in building A because of the Superbowl . Sounds like a good year to take off.
Nautiquehunter
Made some headway today . Set new 351 in the boat to check alignment so I can see if the original stringer design will work with the new engine and mounts without modification. . The good news is the distance between the stringers is the same on both boats and as far as I can see it should line up with the prop shaft. Only question is there a set distance between the strut and the prop I used the rub marks on the shaft to get me close. I don't have a pattern to copy since the engines are different and there are multiple holes in the stringers from the old engine. Not important now but will be needed after new stringers are installed and engine is installed. More good news I think I solved the picture posting problem.
Mike, The "rule of thumb" has been one shaft diameter but some like less. The less distance means less overhung load and that means less load on the shaft One thing to watch out for is prop clearance to the hull. As the prop is moved forward, the clearance is reduced. |
Nautiquehunter
Got It I will check tomorrow.
Nautiquehunter
Another question The original engine came with exhaust manifolds with a 2.5'' exhaust opening . The 351 has 3'' . I don't know if I should go with the original and chance restricted exhaust or go with the 3'' and boar out the hull openings.
Mike,
Since you're dropping the 351 in the hull, I'd go with the 3". Enlarging the holes in the transom and finding new 3" tips should be pretty easy. |
Nautiquehunter
Well my Doug fur source fell through they said even if they could get it it would be very costly. So I went with Southern Yellow Pine . I picked the boards with hardly any knots and straight grain. Probably wont last forever but neither will I.
Nautiquehunter
I decided to put the floor, rear seat and engine cover back on while I had the engine somewhat set in place. Everything went well until I put the engine cover back on . It hits the vent on the valve cover and both exhaust manifold risers. So do I stick with the 86 manifolds with 3'' exhaust ? That will require big modifications to both the hull and engine cover. Or put the 68 exhaust manifolds on with 2.5'' exhaust no modifications needed to engine cover or hull. has anybody ran a 351 with 289 manifolds?
Nautiquehunter
I am missing the section of floor behind the engine cover . Does anyone have any pics of what is supposed to be there and maybe some measurements.
Mike,
The SYP should be fine. Just make sure you do a good CPES job on it and maybe an extra layer of glass on the sides. That will compensate for the strength of the SYP VS: the DF. Do you have a moisture meter? I suggest seeing what the moisture content of the SYP is. |
Measurements? You don't need no stinking measurements. Just make it fit the hole you now have If you really need them I can get them,here are the pictures-
This is an underside picture of that panel with the old plywood removed. It is used to provide support since that panel is removable and has no foam under it. I replaced it with two 1/4" 5ply underlayment CPES'd and bonded to the bottom of the panel. If you look close you can see the lip around the front edge and part way down the side. This makes it looked more finished when its installed. The part of the panel that does not have the lip is under the seat so it's not seen. |
Nautiquehunter
Thanks Gary I just needed to know how long it is. So the foam is supposed to hold up fiberglass floor. I think I will add some cross bracing . The stringer material is inside the heated basement shop it will be quite some time until they are ready to be coated with CPES.
What they originally did Mike was to foam the boat then they laid a layer of glass over the top of everything which sealed it all up. Then that fiberglass pan goes in on top of all that. Here is a picture of my floor you can see where I took out all the foam when I got it in '89. I cut out that top layer of fiberglass but did not cut it flush to the stringers and cross members. There is only one place up in the seating area where there is anywhere close to a foot of unsupported floor. So to protect the fiberglass pan from damage I used that 5 ply underlayment soaked in cpes then epoxy and cloth covered. Supports the floor very well. In the area where the seat tracks screw down, I cut extra pieces of the 5 ply and buttered them underneath to really give the screws something to really hold to.
One area that causes trouble though is where this arrow is pointing. When Correct Craft laid the glass over the foam they gelled it in this area so it blended in with the floor pan. You pull out the foam like I did or replace the stringers like you, this spot will be open. The support floor I put in you can see where I colored the spot that is exposed in that picture above. You will have to figure out how you'll work around this. This is the final result- |
Nautiquehunter
Thanks Gary and I thought The Supra Stringer job was a PITA. I will work something out . Its good to know what they had in mine . The previous owner did all the demolition so I never saw it before. There is no way this boat will ever be as clean as yours.
Nautiquehunter
The real start is near. I pulled the engine and floor back out. Now that I know how things will fit. I think I will go with the original exhaust manifolds with the 2.5 exhaust I hope it wont restrict the flow too much . But a whole lot of modification wont be necessary and I can use the original engine cover. I pulled the boat out of the barn and into the basement or should I call it dry dock. This is where it will stay until its ready for the engine to be installed again.
Nautiquehunter
Nautiquehunter
I promised myself I would not start the 68 until the 08 was cleaned,polished and waxed . After a pinched nerved set me back for a week I felt good enough to work again. 08 is done and put away in the barn To start the new year off right I started the 68. First I spent a couple hours measuring motor mount holes, bulk heads , rudder mount and anything else I found . I marked the specks on a piece of plywood so it doesn't get lost.I then started removing the starboard secondary stringer. It came out surprising easy and intact.Next the primary. She gave me a fight but I also got it out in one piece. Now I have patterns for the new stringers. When I did the 84 Supra there was not much left of the old stringers so everything had to be scribed and planed to fit.
New home until stringers are done |
Nautiquehunter
More progress all four stringers are out most of the work is done on the new stringers. Not much to work with on the starboard side good thing the port side is a mirrored image of the starboard side. I put two scupper holes in the mains and cut a 45 at the back for water drainage. Waiting for CPES and epoxy to coat and bed them in. I will work on bulkheads next I am thinking about every 16'' with scuppers at the bottom to let water through. Atlanta Boat show Thursday.
storm34
Mike - progress looks great!
I have one of these floor panels if you need it. There's a chance I could get it on one of our trucks and arrange a drop off on his way through Atlanta. He won't be able to stop long but if someone could meet him close to the interstate we could make it happen.
Nautiquehunter
Thats the part I am missing. I was going to put in a wood floor and carpet because I never thought I could get that part. Let me know what I need to do to meet. Mike Hunter 678-227-8833
Nautiquehunter
I got all 4 stringers cut and 2 coats of CPES . I noticed the rudder just didn't look right so I took it apart instead of a wood backer board glassed to the hull somebody used plastic attached only with rusty steel carriage bolts . I used MDO plywood coated with CPES and glassed over the top then epoxied to the hull. As long as it was out I went ahead and polished all the brass parts. I got 1 main stringer bedded in with epoxy. I think I can get the rest in tomorrow.
