Distributor plate |
SWANY
Posted: November-02-2018 at 12:13pm |
I'm sure it's a long shot but I'm looking for a points mounting plate for a distributor. Chrysler 440.
phatsat67
Shop around on some of the Mopar forums like Allpar and buy a complete used Dizzy. If you haven't found one by next August I can poke around at the big swap meet.
SWANY
Appreciate the advice. I need to do some more tests to confirm that patronix unit that's in there now is not working. From what I gather I can get a new unit for about a hundred. I'm just trying to get the motor running before I put any serious money into it. Which if that's the case I'd like to just get a whole new distributor when I really tear into the project. Than go to electronic ignition
Grand Poobah Joined: June-06-2004 Location: United States Status: Online Points: 10688 |
What brand of distributor are you dealing with? It's probably a Prestolite with a clipdown cap that uses the same cap and internal parts as the Prestolite marine distributors that came on bunch of Ford and Chevy marine engines. If you post a picture of the distributor with the cap and rotor off, looking straight down at the electronic module and mounting plate that would be a big help. A picture of the ID tag on the distributor would be good too. I just might know somebody with one of those mounting plates |
SWANY
SWANY
Yes it has the clips to hold down the cap |
Ok Joel, what are you working on? Fill us in!
phatsat67
I'm not sure Chrysler ever used a non Chrysler distributor in their marine engines.
That's a Prestolite built distributor (the ID that starts with IBM and the next hard to read digits look to be 4108 tells you that) Chrysler just slapped their own part number on it too. There are some differences from other Prestolites, like the way the holddown clips mount to the housing, but there are a lot of parts they have in common. If you measure the ID of the housing or the OD of the mounting plate for the electronic conversion , the plate should be a little under 3 1/8 inches and the ID of the housing just slightly bigger. The points, condenser, rotor and cap all interchange too. I checked and "that guy" has some parts he could send you if you were to send me a PM with your address |
The cold must be affecting the memory |
Strictly a guess Pete, but I think he's working on what's in the link
Funny selection of tools in the pictures in the link though. link |
phatsat67
Nice, I really haven't touched the Chrysler marine Dizzy much at all. So, they would take the same points as the Ford Prestolite?
My dad's buddy has one in a 72 Century Arabian 440. It had some wonky points in it I had to bend to make work. Dave searched around and found a few NOS OEM points kits for Chrysler marine. Probably much better quality than replacements but it would be nice to be able to snatch up some extra sets if they are the same. |
What do you expect from the "old Dog" as Ken calls me. That was 10 months ago! |
SWANY
Yep that’s the project. I refuse to give up on it. Winter is going to be really slow for me and I am a busy body, so looking forward to get into it more here shortly. Poked around for an hr here and there in the last month with it. I want to get it running, even if it is for 30 seconds before I pull the motor , build a cradle and move into the garage.
Ken, yeah it was full of all kinds of crap that would make someone think otherwise. I’ll send you a pm. Thanks |
Same points, rotor, condenser and cap as the Prestolite clipdown cap distributor for PCM Ford engines
Here are a couple of links to pages from a Sierra marine (same as NAPA) catalog just to have it in print. It's a lot easier to find a Sierra catalog on line than a NAPA catalog. My local NAPA store tells me to bring them a Sierra part number when I want something from them You need to look at the row for 1975-86 PCM 351,460in the PCM chart and the row for an IBM 4108 in the Chrysler chart to compare numbers points 18-5303 rotor 18-5407 cap 18-5369 condenser 18-5345 (strap type) or 18-5347 (wire lead type). They interchange with each other. To me the wire lead one is a whole lot easier to use. Chrysler link Pleasurecraft link |
SWANY
Jesus Ken. You just did all the leg work for me
phatsat67
Good stuff. The wire lead is way way better. Screw that strap style condenser.
I wouldn't but a ton of those points without making sure they work first. I can get them installed in my distributor mostly kinda with a drill and stuff but couldn't get them adjusted without the bending. Pretty sure its the same number i was using at napa a few years ago - but starting two years back they started not fitting. Tried online as above and now I have many more that don't fit right. Had to go with the cheasy conversion this summer. Might just be a problem with a specific supplier?
Hi Joel
Here's a picture of what should show up in a USPS envelope on Thursday Used points, condenser and plate that all worked. I didn't have the wire from the points connection to the coil negative. The Pertronix conversion may have had the resistor removed It'll work for a while without a ballast resistor to see if the engine runs, but if you're gonna stay with points, an Echlin ICR-23 is a good one from NAPA. if you don't have something already. I don't seem to recall mentioning a price and shipping was dirt cheap, so for payment just keep the Wildcat thread up to date so Pete will be happy |
SWANY
My hats off to you, thank you very much
NCH20SKIER
Kind of what is so nice about this site -
'88 BFN |
samudj01
Gold Member Joined: March-10-2009 Location: NC Status: Offline Points: 943 |
Agreed. That is awesome!
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6106 |
I'm sure it's a long shot but I'm looking for a 1997 Masters Edition Nautique.
(Hey, it was worth a shot) |
ArtCozier
I'm pretty sure that Mopar used a Prestolite distributor. You might be able to find one through automotive parts. The Ford/PCM marine engines used it also in the earlier years. The breaker plates just might be the same.
"Art"
