1981 Stern pole light |
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 889 |
Posted: June-16-2018 at 8:40pm |
Lost by prior owner, I need one.
Is there a direct replacement available? I've search, but haven't found... Thx |
1994 Ski Nautique "Riot"
Brian, Are you sure it's not in it's clips under the gunnel? |
gt40KS
Brian I thought the same .... then I found it when installing my deck lights under the gunnels as Pete said - had no idea it was under there. Apparently the last PO's didn't either because it looked like it hadn't been removed in 20 years
JCCI
1995 Ski Nautique GT40 |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21125 |
Check behind the carpeted rear panel in 80-81 as well.
MourningWood
Thanks....MIA...
no rubber holders either. It does appear that they may have been screwed to stringers immediately aft of the rear carpeted panel. So......where can I get one like original? |
MourningWood
Aha.....here they are...
The two rubber clips that retain the stern light pole are screwed to the lower backside of the rear panel. Still need a replacement light pole.... |
