1963 Correct Craft Atom Skier |
Post Reply | Page <1 3456> |
Author | |||
skutsch
Keep at it, you are making unbelievable fast progress. At least yours didn't start like this...
skutsch
Visions of your future???
I think we have some rot... that had to come out total delamination... |
NewOwner
Groupie Joined: November-16-2017 Location: MO Status: Offline Points: 58 |
Wow, what a mess. I would not even think about trying to work with something like this.
Here is my situation. We are moving to a retirement community in Iowa in June. I was hoping to get the boat "fixed" to use on a lake in Minnesota this summer. I had purchased some Total Boat penetrating epoxy to make some small repairs. However, I think I will rent a place to work on it in Iowa and try to have it done for the following summer. In the meantime I will get as much done as possible between now and June. Another question. There is a long piece of vacuum hose attached to the speedometer. What does the other end attach to? |
That's the pitot tubing that's attached to this mounted on the transom: As speed is increased, water pressure at the pitot increases and the speedo needle responds. |
Duane in Indy
Some vessels also use a bronze pitot mounted thru the keel board slightly aft of a point midway between the stem and stern, on a position between the port and starboard gunwales and if you were to raise the sole you might see it just aft of the garboard drain site. in the bilge.
aka the bottom of the boat |
1978 Mustang (modified) |
Grand Poobah Joined: June-06-2004 Location: United States Status: Online Points: 10718 |
Ken,
I wonder if in Duane's circle of car racing, they call core plugs freeze plugs?? Duane, BTW, the hull bottom pitot pickups are not mounted through the "keel board". |
Duane in Indy
Neither one Pete, we use solid aluminum blocks for Nitro Funny car and Top Fuel racing. No coolant for us. And if we did we would use what the lower ranks use. 1 3/4" screw in billet plugs |
So, none of the group drive or own cars or trucks? |
Duane in Indy
Pete, Guess CC put mine in the wrong place then cause they put it in the middle of whatever board that is. |
Don't worry Duane
Pete will straighten you out on all this nautical stuff. Me, I just call it the bottom of the boat |
No Duane, I don't feel CC put that pitot there. Note it's on a glass hull and isn't the bronze version that would have been used back in the day. Also, speedo's for the most part were and aftermarket item. |
I think mine is right in the middle too,right behind the trans/propshaft flange.
Duane in Indy
OOPS, I gel coated mine. Too lazy to mask off. Yes it is original bronze casting. Duane |
Ken, Thanks. Yes I did learn something. Duane, Sorry, I stand corrected. |
Duane in Indy
Thanks Pete, no apology needed. We ALL learn everyday if we open our eyes. Thanks Duane |
NewOwner
I found this in a box of parts that came with the boat. Is this the aforementioned pitot tube? |
Don,
Yes, that a pitot for a speedo. |
NewOwner
Are the wooden braces for the exhaust original equipment or have they been added? Are they necessary when I replace with new tubes? |
Don,
They are original and I suggest using bracing just to keep the exhaust from moving. |
Don,
Any progress to report? |
NewOwner
I have a lot of progress to report. However, I am having trouble loading photos. The forum says that I have already uploaded the photos. Are the photos being stored somewhere? If so, how do I access them?
I have stripped all of the bottom paint off. the bottom appears to be in good shape except where the patch and fiberglass were. I took out the aluminum brace. The center board where the rudder goes through the bottom is split. (reason for the brace?) I have been working on the trailer (tires , lights, bunk boards etc.) so I have a way to transport it when I move next month.. I will post some photos Later. |
Don,
You can't post pictures with the same name or file #. Change the name or name the picture and then try posting it. |
NewOwner
NewOwner
Anyone know where I can purchase a canvas cover for my 1963 correct craft atom skier?
Angola Canvas used to do the covers for the regional distribution center, Midwest Correct Craft . They have in their listings Atom Skier.
Don,
It seems I've neglected to answer your question about that aluminum brace you removed that was between the inner keel and the transom frame. I do not feel it was added due to the split inner keel but I suspect it's to hold the transom to the bottom of the boat. If you dig into the transom I'll wager that you will find the frame to be rotted at the bottom as well as the aft end of the bottom. The area of any wood boat is very prone to rot there because water sits back there. |
NewOwner
I purchased some Total Boat epoxy wood filler will that work here and also on the outside bottom where all of those screw holes are? Or, am I faced with removing the bottom and transom. Can this area be routed out and fixed with some sort of patch?
Don, Re read page 4 Don't forget you have that big gouge from the prop plus I feel you will find plenty of rot. Here's just one of the responses.
