312 Y Block Winterizing/Draining |
Post Reply | Page 12> |
Author | ||
quinner
Posted: October-30-2017 at 10:16pm |
Since I used the Classic a whole 1 time this year it is going to need a drain before winter, Being very new to me, no idea how the 312 plumbing works, will I be looking for (2) block plugs, (1) trans cooler, (2) exhaust manifolds and (1) J-Tube/Hose extraction as a starting point. Any advice/pointers would be much appreciated. Also do I need any pour-in or is drain only OK?? Thanks!!
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10696 |
Shouldn't you check with Charles?
Pete should be able to help you out since he has a 312.
I think I'd drain and then pour a gallon or 2 in the engine to mix with any residual water and let everything drain again |
quinner
That is where I started, He suggested reversing the battery cables so it runs standard rotation and sucking in the pink stuff through the exhaust, I would have done that butt cant find the battery plus I forgot where I parked the boat??
Pure Genius
Good thing you lost the boat |
You've been around this site long enough to know that there's a reference section with some good manuals written by the engineers who designed these things
The 68 Interceptor manual in said location has what look like really good instructions on laying it up. Probably the same as for your 64 .......maybe |
One small problem, that manual was for the new fangled 289 engine and not the y block engines but I'm sure they had block drains
Riley is logged in right now, I bet he'll be able to tell you everything you need to know
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7948 |
There's a manual for that actual engine with the yellowish cover in the reference section.. Pretty much like any Ford. There's a plug on each side of the block, a drain on each exhaust manifold, and a plug on the bottom of the raw water pump. I remove the intake hose off the bottom of the raw water pump. Getting the anti freeze in the engine is a little different, although your set up may be easier as you only have one thermostat.
I always pour in that special -100 stuff and make sure it runs out with good color, then I pickle it. I'm beginning to think pickling is a waste of time and money, but can't break myself of the habit. |
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 888 |
Those drain points match my '64 312: (in S F Bay Area) i run until warm, then suck up 50/50 coolant mix while running in some fuel stabilizer. Also do an oil/filter change so any fuel contamination doesn't affect bearings. Boat is stored inside. Seems to be working out. |
quinner
You guys really made me work for this one, lol
Since mine is a downdraft, which both Zach and Timmy believe is original, I referenced that motor, looks to be pretty straight forward. Is there any Diesel oils left that have the ZDDP I need, motor is leaking pretty bad so hate to use the high dollar VR oil until I really know the true health of this motor?? Pretty sure Pete mailed the cap, rotor & points last year, so should have those any day now |
Riley
I'd use straight Rotella 30W. Best deal for it is at Walmart.. $16/gal last I saw.
VR-1 is at Farm and Fleet for 4.50 a qt and at Menards for 4.99 after 11% rebate, 4.44 if you don't want to get all dressed up to go to Walmart
Chris,
Glad you found the engine manual! How did the Classic run the one time you had it out? |
quinner
After Zach and Timmy messed with it she ran well enough to pull Boziel on a slalom. Going to give it some loving this winter, needs a good scrubbing and then a physical, likely a complete tune-up and then a full rubbing/polish. Eventually try and do something with the bottom paint or finish and finally get my new to me trailer from Bruce up here from Reidland for it's resto.
Last time I visited Uncle Wally ( couple of hours ago) I checked out the 15w40 stuff and good ole' Supertech 15w40 still has the CJ-4 rating and plenty of zinc (And cheap but good $ 9.88 a gallon)
The latest Rotella T-4 15w40 still has plenty of zinc too, but some people just can't get past the lack of a gas engine rating like SM or SN. Others can and still use it Click on Shell Rotella T4 Triple Protection tested on 3/30/17. That's the CK-4 rated stuff They update it as they test stuff so you have to pay attention to dates and ratings. PQIA diesel oil link |
quinner
No I did not search because I know you guys have the answer, what oil filter does this block use? The one on there now is some crazy off brand and looks like it was installed with a hammer.
The drain plug on the water pump is a disaster, going to try a vice grip to get it off and then replace it, thank you HW for looking at it for me as I could not contort enough to see what the heck it was, lol. |
Riley
You should have Hollywood remove the pump and replace the impellers while he's down there..
We use a NAPA Gold 1521 oil filter. |
Or a Napa Gold 1068 which is the shorter version if there is a clearance problem to a stringer like my X55 has. |
I figure your 1068 is the shorter version of something but it's not the shorter version of a 1521. The 1521 is 3.78 inches long Your 1068 is 4.33 inches long A 1515 is 5.19 inches long so you would have the shorter version of that. So Pete, yours is longer than Riley's |
quinner
Definitely going with the 1515 then as I need every inch I can get!!
Thanks Guys!! |
Riley
Let us know how that 1515 works out. You may want to pick up a Sawzall while you're at NAPA.
Well big boy, if you're lookin' for length you might want a NAPA 1773. It's the length enhanced version, it's about 7 inches long. Riley's will fit for sure though |
Riley
LOL, if 5.19" is good, 7" got to be better! All it needs is a few floor modifications.
You must be getting old and forgetful Quinner, you asked the oil filter question back in the thread linked below
old thread Actually my main reason for linking the thread was to remind Pete about sending you his Sierra ignition kit that he'll never ever use. Or he'll never admit that he'd use it anyways |
quinner
LOL, I just searched that one out this am to make a list of ignition parts needed that have not arrived in the mail yet :) and did see the oil filter recommendation, good to see our information database is consistent and expanding, literally!!
Well Ken, now that you have once again worked me over bringing up the Sierra kit, I dug it out and took a closer look at it. Talk about forgetfulness, the parts in the kit are used so, I DID use the kit!! |
Gotta keep old minds active Pete, I'm just doing my part. I'm not sure about you though, first we find out you have an electronic ignition module in the Tique and now you've used Sierra ignition parts in the Dunphy.at some point in time What kind of secrets are you hiding in the Atom? |
I'm gonna take a guess that you have a custom built Vertex magneto providing the spark to that 4 banger
Hollywood
ProTec
