carburetor |
randy simmons
Newbie Joined: October-16-2017 Location: blackshear ga Status: Offline Points: 17 |
Posted: October-25-2017 at 1:40pm |
Anyone know why a 3310-2 holley carb would be on my 1980 ski nautique . 351 engine. Do I rebuild this or replace with correct carb. New boat owner.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21120 |
A quick search reveals a 3310-2 is a 750cfm 4150 Auto carb... not original and a safety hazard.
Best to replace with a marine 600cfm. QF makes a nice one if buying new. |
Randy,
Considering the carb is auto, I suggest you look at other components the PO used that will put you in danger running the boat. |
randy simmons
Thanks for replies. Gonna order new one from QF.
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Offline Points: 6148 |
Or buy the 600CFM Holley Duane just posted in the parts for sale section. Saves you a few bucks and if it is coming from him you know it's good to go.
But, if you decide to go Quick Fuel route you will not be disappointed. Like Pete said. Take a look at the fuel system/electrical system to make sure there are no other misused automotive parts lurking. |
scootdogydog
Senior Member Joined: November-03-2013 Location: Central MA Status: Offline Points: 404 |
Or save a few hundred and buy Duane's that he just posted.
Note that I'm commissioned 😉 |
randy simmons
Thanks for help. Didn't go either way yet. Gonna make sure new carb is gonna fix most of my problems.
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3333 |
Maybe i'm mistaken in understanding your phrasing, but either way, auto carb has to go, for a multitude of reasons.
Post a picture or two under the hood, we can usually identify things out of place, |
River Rat to Mole |
phatsat67
What he said ^^^
A proper marine carb is necessary either way. The automotive carburetor on your boat is a fire risk and also would most likely devoid you of any insurance compensation if there were a fire on the boat. What other problems are you having? |
randy simmons
Not sure about other problems until we get motor running. Not sure if motor will even run with new carb. Mechanic is going to clean old carb just too see if motor runs. If runs I will then buy correct carb. Does this make sense?
randy simmons
Also gonna try and post some pictures today. Thanks again for all the help.
phatsat67
Yes, makes sense now. We had no idea of the previous running condition of the engine based on this thread. Good luck with and keep us posted.
Is your mechanic a marine guy or a car guy? Lots of times good car mechanics overlook the special requirements of marine engines. Best to keep in touch with everyone here on advice when getting this thing water ready. |
randy simmons
He is a marine mechanic. Can fix or rebuild anything. Maybe get running morrow and post some pictures of boat. Will sell or giveaway wrong carb and purchase correct one.
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2861 |
This is what you want:
https://www.summitracing.com/parts/qft-m-600 JQ |
