ZDDP Question |
Post Reply | Page <1234> |
rosconole
yes, so far sounds like 10w-40 or 15w-40 , just have to look at the data a little closer to get apples to apples. specs have changed , epa regs have changed so you almost have to throw alot out the window and hope the man following too close behind you.
Pete, AMS Oil has a ZDDP line for old engines. I've never used it as we use either VR1 or Straight Rotella in our boats. I have used AMS Oil 15-45 in our Malibu since new. I used to use it in my trucks, but no longer do as it is a PIA to find a shop that stocks it. Plus its expensive!
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3605 |
Rotella and Delo are on the shelf at Walmart, SAMs and most parts stores and has the ZDDP in 15-40W. Less than $20 per gallon. Not hard to find and it works.
And the HD even stocks it! |
rosconole
I was referring to the sae 40W not as easy to find it "on the shelf" not any current engine that probably specs it besides some tractor or generator. its got delo 40w last time I changed it after I bought boat last year.
Straight 40 is the factory specified oil for most any Detroit 2 stroke.
Had the darnedest time trying to convince the fd leadership till i showed it in black and white, and they were still skeptical. typical. So, sniff out where 2s detroit owners go, we'll fine the straight 40W |
Just to state a fact, Detroit designed those 2 stroke Diesels 50 years ago and that 40W was probably the best option, back then. 50 years later in 2018 if you go to any Diesel Repair or Parts house you see 15-40W on the shelf. These Brand new Diesel engines still require the ZDDP in the oil so even the 15-40W has it and these Diesel repair and parts houses do not stock straight 40W any longer.
Buy Joe Gibbs or Royal purple if you wish but the 15-40W Diesel oil will work for you just fine. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10728 |
Back in the second post of this thread last summer there was a link to this thread that talked about changes in diesel oil.
CK-4 is the latest rating, it's been around for about a year now and some but not all CK-4 oil is lower in zinc with levels of about 800 or so ppm Rotella T-4 and Valvoline Premium Blue 15w 40 diesel oil both have high zinc levels still in spite of their CK-4 rating. Chevron Delo and Mobil Delvac, I 'll let you read the charts With the previous rating of CJ-4 it was safe to say that any 15w40 diesel oil had the zinc levels people are looking for. With the advent of CK-4 it's now a crap shoot. You can still find CJ-4 diesel oils with good zinc levels, you just have to read the labeling on the bottle and look at thePQIA link here to see what they have for zinc/phosphorus levels in the stuff they tested. |
Duane in Indy
Like I've said before, add a can of Lucas ZDDP additive to your favorite oil and forget about it. That is what it is made for.
1978 Mustang (modified) |
Thanks for the link Keno.
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2864 |
+1 on what Duane sez... |
Duane in Indy
At $14.00 a bottle/per oil change, I'll stick with using oil that already has ZDDP in it. |
Duane in Indy
I'll still use VR=1 and not worry about it.. BUT if your favorite oil does not contain enough zinc then this is an alternative.
Must be a cold hard winter to have beat this thread so long, and to have done it last year also. |
Duane, I'm sure it will continue with more winters in the future! |
rosconole
I'll stay away from the Lucas I saw them on the questionable list on the independent testing, i never was a proponent of putting in additives to oil BUT I have seen how will the Archoil helps my injectors in powerstroke during startup.
If I go away from the Delo 40, I probably end up using 15w40 marine & diesel amsoil since I can use the same in powerstroke and buy in 5 gallons at a time @ 133 for my dealer price. |
Great price. I pay $90~ for 2.5 gals at NAPA. |
$9/qt, ouch.
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4241 |
I didn't know you can buy Amsoil at Napa? Thought it had to be through a dealer.
I used the Amsoil Diesel & Marine 15-40 in a Suburban diesel that I did a test on with the help of an Amsoil dealer, we did uoa on every change. It's an outstanding oil. |
For you midwest guys, Menards has VR-1 for 4.99 a quart and a .55 cent rebate til the 27th. Blains Farm and Fleet usually carries it for 4.50 a quart.
Yeah, but we get 2-3% increase in RPM with it! |
But I know where to get the decals that increase my HP
That's not as good.
rosconole
ZDDP is actually only specd at break in so its a moot point now really. Sure probably a higher number is better with a flat tappet. Would have been nice if they used roller motor instead.
Ross, Lots including myself have a different opinion. I have seen first hand the damage done when non ZDDP oils were used on well broken in flat tappet engines. |
Ross, Pete is correct. If you don't want to use zddp install a roller camshaft and lifters.
Flat tappet cams need zddp for protection against wear. Mark |
Ross, Hopefully you haven't gone to a non ZDDP oil!! |
rosconole
OH NO! I better go order a new ZR409 right now just in case!!!!!!! Anyone got a spare Python motor !!!!???
If you guys are gonna disagree with Roscoe, could you at least get your info straight.
You talk about motor oil with no ZDDP................all MOTOR OIL has ZDDP in it. Some have more than others The newer passenger car motor oils have 700 to 850 ppm zinc and the generally accepted magic number is around 1100 to 1200 ppm for older flat tappet engines. I figure, to each his own, if Roscoe wants to run a lower zinc oil he can take his chances, it's his engine I'm still trying to figure out why the Jeep Cherokee I had that fell apart around the engine was still running just fine with 250,000 plus miles on low ZDDP/zinc oil of around 800 ppm. No camshaft /lifter issues, just good old salt related rust issues. Here's a link to the PQIA website where you can look at the oils they tested and see zinc and phosphorus levels in both the passenger car oil section and the diesel oil section PQIA |
Jeeze Ken, now I guess we'll need to start even more ZDDP oil threads!! One for old school off road high ZDDP oils and another for new school EPA approved catalytic converter protecting low ZDDP oils!! |
