Strut replacement in Fish Nautique |
Thanks(1)
Posted: July-11-2017 at 4:52pm |
Mark,
3M makes the 4200 - 5200 series of polyurethane adhesive sellers. |
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3604 |
Remove the strut and re mount it favorably. There is a ton of information on doing this job on this forum. I had to add some washers and sand my strut to get it in alignment but it has been perfect for 3 years since.
The old strut will not fall off, they are glued on pretty tight. I used wood door shims and knocked them between the boat and the strut. I kept working in more shims till It broke loose. The wood did no damage to my boat. I cleaned off the old glue with my automotive gasket scraper which I keep very sharp. Had to be careful not to cut into the boat bottom. This entire area is covered by the strut so I had no worry about cosmetics. On install it is recommended by many here to use 4200 calk rather than the 5200. The 5200 is much harder to remove. Do some reading though and get up to speed before jumping into this repair. Your log can be repaired with labor and nearly no money installing new fiberglass. Again this forum has former posts advising exactly how to do this correctly. The name of the glue/calk maker escapes me but it is one of the major companies, Dow or 3M. Others will chime in. Mark |
BMo
Newbie Joined: July-14-2016 Location: Seattle Status: Offline Points: 14 |
Thanks for the responses, the strut bend is barely visible, however, the shaft has worn one side of the shaft log and there is now a small crack in the shaft log on the worn side. The engine seems to be already adjusted to the other side to account for this. Hence, my belief the strut is bent, even though it is not obvious visually. I acquired the boat last Fall and have been working on it all winter, but had not yet had it in the water until last week when we discovered the crack in the shaft log. Will post some pics soon.
I had a strut straightened a number of years ago on an 83 SN, but subsequently it was never quite right. Would prefer to have a new one but it seems the chances of finding a new one is very slim. Thank you Gary S for the lead with Florida Inboards. Will check it out. If anyone else has a lead on a Fish that is being parted out, I would love to get contact info. |
Check with Jody at Florida inboards link He had a fish he was going to fix up- don't know if he parted it or sold it. If you find one I still would not throw the old one out, I'd get it fixed if possible.
Brian,
How badly bent is it? I've seen some pretty bad struts straightened. What bothers you regarding straightening? Post a picture. |
BMo
Looking for a new strut for a 1987 Fish Nautique resto. Spoke to Correct Craft factory parts and they told me they think it was a proprietary part made by their own foundry. None in stock. Also checked with Buck Algonquin and they told me the same thing. Would prefer to find a new one than attempt to straighten the existing one, but it looks like a new one may be impossible. Anyone attempted to have one remanufactured/cast by a local foundry? Any advice would be appreciated.
