Steering cable showrooming.... |
seacamper
Platinum Member Joined: June-24-2010 Location: Florida Status: Offline Points: 1056 |
Posted: January-23-2016 at 1:36pm |
Hey Guys,
I want to buy a steering cable from a reputable place, but I could not help myself from "Online Showrooming" (comparing prices). Anyhoo, this seems to be what I want for considerably less: Steer cable My current cable has SSC6217 stamped on it. Anyone have an input? Thanks Tom Dang, I just checked the link, and it directs to the home page. If you type in SSC6217 the correct cable comes up.. I guess you can just copy and paste this: http://www.starmarinedepot.com/seastar-ssc62-qcii-steering-cable-replacement-17%27.html |
1980 Ski Nautique Boat Bar
1988 Mastercraft Tristar Open Bow 1988 Mastercraft Tristar Closed Bow 1969 Seacamper Houseboat 1986 Harris Pontoon 2004 Seadoo GTX SC + Flydive Xboard 1999 Adventurecraft |
seacamper
Uh, little help please. I really think my steering cable question is more important than your feeble blizzard problems, especially when it comes to saving ME money.
17' is correct. Th SSC62xx series does not appear to be correct unless someone swapped out your Big-T helm with a lesser version (Safe-T, NFB, etc). Crawl under the dash and see if you can match up your helm to pics online before you order a cable. The SSC61xx series is what crosses to the Big-T. It's ~$15 more expensive than the 61. I usually order my generic steering cables from go2marine, $105 for the ssc6117 and free shipping over $100. Might want to get a few control cables at the same time if you're due (plus pivots).
seacamper
IAughtNaut
why change it? you keep cranking on it the way that it is and you're arms will be buff as hell. better than paying for a gym membership if you ask me.
seacamper
I will call it "steer-o-flex".
Smithfamily
Adam's always thinking. (of ways to avoid a mechanical repair!) |
Js
seacamper
seacamper
Interesting. Here is a thread that suggests that the 61XX line replaces both the old Morse cables as well as 62XX cables. Pretty good info for further steering cable confusion:
Teleflex I guess I can go with either the 61XX or the 62XX. |
seacamper
Go2 Marine Description
QC II Replacement Steering Cable - SSC61 Teleflex QC II Replacement steering cables feature the patented QC - Quick Connect - cable system. These Teleflex QC II cables supersede many Teleflex steering cables, including Teleflex Big-T single station cable steering, for boats with inboards, outboards & stern drives, with one or two engines. The QC II is the one cable you need for nearly all Teleflex rotary steering since 1968! Direct replacement for SSC62 & SSC72 cables, so it fits the following complete systems: Fits the SS132, SS137 and SS147 rotary steering system Safe-T QC stern drive steering - SS137 NFB Safe-T II outboard steering - SS132 NFB 4.2 outboard steering - SS147 Single station push-pull Big-T steering systems - SH500P Safe-T Threaded Spigot Steering Cable - SSC72 |
phatsat67
61 and 62 are the differences in the nose of the cable where it goes into the helm. There is an adapter on your cable that allows you to screw it onto the helm the one Tim mentioned probably doesn't need an adapter to fit the Big-T.
just have jbear crawl under there and figure it out. little extra hair spray maybe
Can't tell from that angle which helm you have but I like Zach's theory. If you confirm you have a Big T then I'd go with the proper cable vs using the adapter but that's just me.
seacamper
I probably screwed up, but since a 6217 came out of it, I just picked up a 6217 locally for $83. I will know tomorrow if I have a chance to put it in.
