1969 Correct Craft Barracuda |
Post Reply | Page <12 |
62 wood
WOW!! I have the same "YH" carb adapter on my bad 6 as your V12!
(just not quite as many of them) |
62 wood
btw, are the vertical tubes the exhaust/ you gonna run dry?
Nautilus
Senior Member Joined: June-25-2013 Location: West Union, SC Status: Offline Points: 131 |
Yes. No need for water-jacketed exhausts. The engine will be completely exposed.
Striving for mediocrity !
Jan,
Was the Shepard originally a V drive? I know they loved to use them. |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4239 |
Yes, I'd say that boat will work for your "purpose" quite nicely!
Don't some of the diesel inboards use 2:1 transmissions? I'd almost think that would be the ticket for the low rpm and torque of that engine. Very cool, I can't wait to hear it run. |
Your logic is backwards on the transmission... A low revving engine that wants to run higher speeds would benefit from a lower reduction or even an overdrive (<1:1) tranny. That would get prop speed higher (and allow use of a shorter prop).
High torque, low rev diesels usually go in larger/heavier/slower boats and the larger reduction further allows them to turn large props at low speeds. I think JohnB has a good theory on the power of attraction that old, loud boats have. |
Nautilus
For now, I'll proceed with Michigan Wheel's recommendation. If I don't like the results, I can always change the transmission and/or prop.
quinner
Heavy metal and a Woody to get chicks, yea that should work!! You may want to keep the Ruffies as Plan "B" just in case!! |
63 Skier
Thanks for the explanation Tim. I looked at a Peninsular 6.5 ad and talked to the seller last winter, had a 2:1 mated to it, but as you pointed out must have been thinking backwards about it.
peter1234
if you are hoping to grab senior women you might need to put saggy between big and boobs
Nautilus
At my age, you learn to accept gravity. |
It's the size of the 401K that really counts . . .
Jan,
You must have missed my question. From the picture you posted, the Shepard looks like a DD but as mentioned, they did love the VD's.
Jan, Still missed the question? Don't forget we'd love to see more pictures of both the Shepard and Dee Wite. |
northcoastidol
Senior Member Joined: March-28-2013 Location: Garfield Hts Oh Status: Offline Points: 100 |
Always be ready for a run, the water does not wait for you!
