  New Posts New Posts RSS Feed - Bent shaft?
Bent shaft?
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Topic: Bent shaft?
    Posted: April-22-2014 at 7:44am
Pete, Tim and other specialists...
A video tells more than a thousand words, so I took my smartphone:
So, is my shaft bent?
When I put a long screwdriver next to the shaft (tip pointed on the bilge floor and screwdriver shaft next to prop shaft, for lack of a better explanation by a non-english speaking forreigner )I can see it move back and forth a little (read: half a millimeter)
There is no play whatsoever in the strut, prop looks fine and shaft moves nice and freely (checked alignment last week).
I have a negligeable vibration between 2100 and 2150 RPM (between 30-35 KPH, 19-21 MPH)...
Should I start to panic by now...??
ny_nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ny_nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2014 at 8:33am
Here's the video:
- Jeff
1999 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2014 at 10:48am
Oops, sorry, my bad... Edited my post.
Thanks Jeff
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2014 at 10:48am
Get a dial indicator Kris. That will tell you for sure and you'll use it again with all your mechanical skill.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2014 at 11:00am
Ha, that's one of the answers I expected Zach
But, before I spend yet more money on the B(reak)O(ut)A(nother)T(housand), what is your opinion on what you see in the video?
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2014 at 11:17am
It looks like its moving the shaft log around a bit but that could be inconsistency in the shaft packing? The spec for tolerance in a shaft is .003 or less run out. So its a pretty tight spec but a little room for error.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2014 at 8:12pm
Kristof,
I agree with getting the dial indicator out. Besides the shaft, the coupling could be an issue too. Ether with a bad fit to the shaft or a coupling face that isn't running true to the shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2014 at 7:15am
So dial indiactor it is... I'll get back to ya
