questions about ProTec replacements |
Author | |||
JPASS
Posted: July-25-2013 at 12:23pm |
I like using Summit, so this is good. Thanks for the link and the help. |
'92 Correctcraft Ski Nautique
You can get the cap and rotor kits from Summit, just like you can get the full up DUI. Though, since the price is the same, I'd order the DUI directly from Davis in case they want to make any changes to the advance curve off their base tune- they take your engine specs when you order.
JPASS
Good to know. Are the cap and rotor pretty easy to source or do I need to get hem through the same company that sells the DUI? |
The DUI's use a magnetic pick up instead of points. Cap and rotor are both maintenance items, just like every other distributor. "Fully computerized" is pretty misleading, as it is still a mechanical advance distributor with weights and springs. They do tend to have very nice advance curves and strong spark, both of which improve all around performance compared to the Prestolites and Mallories- at least in my experience. I have 2 in my boats. As described, hook up couldnt be easier.
Plug wires are a maintenance item, and will need to be replaced regardless of which style distributor you go with. The protec wires are too short to reach the front of the motor even if they did have the right terminals. The DUI Live Wires are very nice, but pricey. I have always opted for the universal Taylor Spiro Pro wires (~$60 from Summit), and cut them to the lengths I want with the terminal styles I need (it comes with both male and female). Regarding the Protec wiring, very little *needs* to be disconnected. The oil and water temp switches, as well as the knock sensor simply become dormant. If going with a DUI, you may need to extend a few wires (ign and tach) so they reach the front of the motor, but that is pretty straightforward. |
JPASS
Does it still have a rotor that needs periodic replacement? I noticed the unit is $385 + $100 for the plug wires. |
89Martinique
Senior Member Joined: September-05-2011 Location: Binghamton Status: Offline Points: 457 |
A DUI is a fully computerized dist. Like waterdog said. GM made HEI dizzys and they worked pretty well. Powerful and very low maintenance. DUI just made one for Ford.
Current Boats:
1992 Supra Comp-TS6M PCM 351w HO Pro Boss Pro-Tec Ignition - Full Composite (no wood stingers!) 1989 (3rd Gen) Correct Craft Martinique B/R PCM 351w Power Plus 1984 E-Scow Keuka Lake, |
Waterdog
DUI = A modified GM HEI and open up the plugs (.050)
JPASS
Are there points and such on the DUI? I'm under the impression the DUI is kinda maintenance free with the only thing needing replacement being the rotor? Is this correct? |
89Martinique
I'd just do the DUI. No ballast resistor, no coil, no starter bypass wires to mess with. Just 2 wires, +12 volts, and tach, DONE! Full computerized dist and high energy coil all built into one unit. Clean look too. Just transfer the plug wires from coil pack to Dist in right order, unplug coil pack harness, take +12 volt and tach wire from coil pack harness and reroute to new DUI. Easy...
Current Boats:
JPASS
No 7AM slalom for me. Definitely want to get the Y pipe conversion, but its a little further down on my list-O-things to fix/replace. I'll definitely hit you up when the time comes to make the swap. I'm leaning more towards the DUI, but I'm still researching them both. Thanks. |
89Martinique
haha. boy, people sure know when Im skiing!
Current Boats:
halfnelly
Senior Member Joined: January-14-2013 Location: Maitland, FL Status: Offline Points: 253 |
Loud boats are great, unless you like to slalom at 7AM before the wallies start driving through the course. Competition inboards are designed for the 7AM tournament skier.
I did the SkiDim conversion on my '94 Sport, if you have any questions shoot me a PM. |
89Martinique
Wow, that blows. The only thing Keuka Lake prevents is dry exhaust. So we have plenty of loud boats. Nothing like hearing 3 or more of them cigarettes with twin Big Blocks racing down the lake!
If your watching your boat drive away, can you hear it more than a 1/4 mile away? |
Current Boats:
JPASS
It's not very loud, but then again I have nothing to compare it to. It's probably better that it's quiet because the cops on our local lakes have a hard on for loud boats. I've been harassed about my loud jetski many a time on the local lakes.
89Martinique
Is that thing as quiet as my 89 Martinique? Boy, I have to say i was VERY Dissapointed when I got up and cruising with my CC. We bought it on ebay for $5k and had relatives check it out at Sunapee Lake. Said it was is good shape so finalized the deal. Few weeks later went up with friends and took the boat out for a fall run. Noticed new exhaust setup, got out of the harbor and was DISSAPOINTED! Heartbroken! ITS QUIET! My uncles Gen II Martinique(86~88?), that sits at the family house has the good ol' dual 3" exhaust that you can HEAR! I cant believe cc got into the "good neighbor" crap. Im glad my Supra is as loud as a 351W can get. It has to make up for the lacking cc.
Current Boats:
JPASS
Here is a pic of the rest of the motor: thread |
89Martinique
you have the HO Pro Boss Pro Tec Ignition. Same as me. It features Ford gt40 heads with a Holley 4010 carb. Great combo. Sadly I don't have the gt40 heads anymore. But will be getting some next year!
EDIT: Now, CC got into the "friendly neighbor policy" so I don't know if your motor has them or not (another pic would tell) but your motor should also feature short 3.5" risers, allowing for better exhaust flow. Supra did this with a nice big muffler that has dual 3.5" in and out. Great flow (great sound when hollowed out!) |
Current Boats:
TX Foilhead
Pro Boss with throttle body fuel injection. GT40 has the very recognizable tubular intake with the large box above the valve cover on one side.
JPASS
here are some pics
Bri892001
Do you have any pictures?
The Pro Boss has GT-40 heads, and is usually around 285 HP. There was a later engine, called the "GT-40", that again had the GT-40 Heads but also full fuel injection (as opposed to throttle body injection). These are quite a bit different looking on the outside. Skidim offers this handy guide: http://www.skidim.com/marinization.asp |
JPASS
PO's ad said it had the GT40 in it. How can I tell?
Model nbr off the engine tag is: PLP-PR-R12PT |
A GT40 is a Windsor. The designation is simply the build level of the Windsor block. |
JPASS
What, if any, is the difference between a windsor and a gt40?
You should have an ID tag on the engine. See if there is one and then go to the ref section under PCM. There's a good explanation on IDing the engine. I agree that unless someone did a conversion, you have a Windsor. With very minor exceptions, Cleveland and Windsor parts do not mix. |
89Martinique
the cleveland was not very long lived. I have yet to see one for real. PCM only used windsor motors, not clevelands. (i know pcm did use many others) Just look at pics of cleveland motors vs winsdors, and you will see that you have a windsor. Clevelands dont have the thermostat built into the intake manifold.
Current Boats:
JPASS
pulleys spin clockwise and the prop is a right hand prop. So it appears I have the Windsor. Are there any stampings on the motor that can confirm this as well?
Bri892001
You definitely have a Windsor. 99.9% positive unless someone did a really oddball swaparoo at some point.
You most likely have a Left Hand (Standard Automotive) rotation engine. Even though your prop is most likely a rightie, the "Power Plus" Transmission reversed the direction. You want to confirm this though. When your motor is running, your pulleys should be spinning Clockwise, as observed from the spotters seat for Left Hand (Standard). |
JPASS
So I called Performance distributers today to ask a few questions about their ignitions. They asked if my 351 was a cleveland or windsor. I said I didn't know.
Any idea how to check? All I know is it is a 351 PCM with the ProTec ignition. I also do not know if it is reverse rotation or not. |
JPASS
I have the wiring schematic for my boat and can see what you are talking about. Good question about weather the SkiDim retro kit will still allow for the auto shutdown and limp mode. Not a deal breaker, but a cool feature I'd like to keep if possible. |
desertskier
On page 51 of the PCM engine manual (site reference section)there is the Engine Wiring Diagram for 351 Ford Pro-Tec. Looking at this schematic I think you can just disconnect the EMS connector and Trigger plug. At the EMS connector the wire going to pin P (point 26) is 12V from the 12.5 Amp breaker and pin E (point 34) would be the tach wire going to the wire harness plug that goes to the dash. As long as you disconnect the the wire at the 12.5 Amp breaker so it doesn't put 12V on the open connector I think that would be all you have to do. Connect the DUI to the 12.5 Amp breaker output at point 26 and the tach wire going back to the dash and your done. There is nothing else on the EMS connector or trigger plug that would be used or matter, they could just be secured and forgotten about. Keep in mind that automatic engine shutdown, limp mode etc.. is history. Although your oil and temp guages will still function normally. The skidim kit may still have that functionality, not sure.
